Call your local Cat dealer ,Parts department should be able to lookup the numbers ,and tell you the models those bearings were used in .Some of those numbers probably change up .
Are these crank shaft bearings ? The 5F bearings look to be something for a D4600, the 6N and 7N are too new for me to look up.
