Cat 988 wheel loader
Showing 1 to 10 of 10 results
4LFarm
Send a private message to 4LFarm
Looking at a 1971 988 WHEEL LOADER can anyone tell me the good or bad of these? It's priced for my pocketbook but bigger than 90 percent of my needs so...I kinda want it!
Wed, Apr 13, 2022 10:40 PM
4LFarm
S/N 87A1120 in case it matters
Wed, Apr 13, 2022 10:43 PM
Thank you received: 113
Reply to 4LFarm:
Hi, 4LFarm.
They were/are a pretty solid machine, not many bugs at all that I am aware of. I spent some time on a couple of them, earlier versions than this, in 1968-69.
Thu, Apr 14, 2022 5:30 AM
d9gdon
Hi, 4LFarm.
They had the D343 engine which had a good reputation.
Thu, Apr 14, 2022 6:11 AM
74A6C
Send a private message to 74A6C
Reply to d9gdon:
If you need a little bit of wheel loader, a lot of wheel loader should do... Go for it.
Sat, Apr 16, 2022 10:02 AM
caterpillar13
Reply to 74A6C:
go big or go home😁, just like a shed, they never are big enough
Sat, Apr 16, 2022 10:35 AM
Thank you received: 64
Reply to caterpillar13:
Very true about sheds : ) You do have to be a bit careful with sizing loaders though because if it's too big for the job, it can be noticeably slower than a smaller loader. For things like unloading log trucks and quarry work, bigger is almost always better but if you're stacking smaller objects like round bales or moving around in small spaces, an oversized loader can be much less efficient than a right-sized loader. If you aren't trying to beat the clock though, that's not an issue. Enjoy!
Sat, Apr 16, 2022 8:44 PM
Fat Dan
A 988 and in your price range too.
Hummm is that a question or a statement because that is a no brainier for me? Neil dose make a good argument, all I'd add is those things run on lots of oil and parts are big so it is best if you own a small herd of to keep each other company.
Pictures please.
Sun, Apr 17, 2022 6:44 AM
Reply to Fat Dan:
Pictures please.
Hi, Neil.
I might be a ovva smar tass but I once levelled fill for a single vehicle carport and access ramp leading down to a sloping driveway which meant the access ramp changed shape on the way down. What did I do it with? A Cat 990 loader while using a 5-gallon drum as a seat.
Where there's a will, there's often a way.
(NAH!!!!!!!!!!!!!! Where there's a will, there's a lawsuit.)
Wed, Apr 20, 2022 9:15 AM
mog5858
Hi, Neil.
one thing to think about is if you don't have solid ground that loader will pound right through. if you get a 988 stuck you'll need something BIGGER to pull it out. but just a simple tire change will cost over 1000 just to get tires to shop out to change a tube or valve stem. a tire will be 5000 +. too big can be hard to get around or fit in a tight spot. if you're going to be in out a lot 988 will have about 5-6 steps up a leader to get in and out of the cab, which could get very old quickly. it all comes down to your needs are you loading gravel or just moving a few hay bails with it. Jpay dirt runs a 988A in his youtube videos might give you an idea of how fast it can rut up soft ground and how one runs. they are not snappy or rompey like new loaders are more of a slow giant
Sat, Apr 23, 2022 9:40 PM
74A6C
Reply to mog5858:
I've secretly been wondering who would mention Paydirt's (Anderson Construction) 988.
Sun, Apr 24, 2022 5:48 AM
