Cat 977L transmission oil and hydraulic oil capacity and type
ksliger
Send a private message to ksliger
Greetings,
I can't seem to find the information for 977L oil capacity for hydraulic and transmission. Can someone please provide these specs? I do see that Cat calls for HYDO in the hydraulic system. Should I run straight SAE 30 in the transmission or TDTO? Thanks in advance!
Sat, Jul 27, 2024 3:52 AM
seiscat
Use TDTO in the transmission.
I don't know the answer to your question about the hydraulic system but that answer and more can be found in the operator's guide for your 977L.
I found this one on eBay:
https://www.ebay.com/itm/235060818513
Sat, Jul 27, 2024 7:55 PM
ksliger
Reply to seiscat:
Thank you! I ordered a guide last night
Sat, Jul 27, 2024 9:13 PM
bluox
Reply to ksliger:
Look on the back pages of your parts book under specifications and you will find capacities for lube systems, cooling, hydraulic and fuel.
You don't need to use HYDO or TDTO unless Cat has it on sale.
Look under the dash for the info plate with serial number.
Bob
Mon, Jul 29, 2024 8:13 AM
| Kingaroy, Queensland
