Cat 977L - safely locking the lifting arms upright
Showing 1 to 9 of 9 results
ksliger
Send a private message to ksliger
Greetings,I purchased a new to me 977L today. I am still searching for a SN but I think it is over 11K8516 because it is missing the older style "link" that is used to lock the lifting arms up. Can someone please educate me on how the lifting alarms are locked upright in 977L's with SN over 11K8516? The first picture below shows the older style with the link. The second picture shows the newer style with no link. The third picture shows the part book illustration of the newer style with no link. Thanks in advance!
 [attachment=77239]safety link.jpg[/attachment] [attachment=77241]new style.jpg[/attachment] [attachment=77240]no link illustration.jpg[/attachment]
Tue, Jul 30, 2024 8:35 AM
GMBM
Send a private message to GMBM
Its been a long time but didn't they have a brace that would be stored on the tilt cyl using the two blocks shown in the second picture
Greg
Tue, Jul 30, 2024 5:24 PM
Thank you received: 130
Reply to GMBM:
Greg
Hi, ksliger.
The later Cat track loaders did have a brace that slipped over the extended lift ram rod between the ram cylinder and the rod end to hold them up in the raised position - often stored under the seat at the rear and usually painted RED.
Wed, Jul 31, 2024 8:25 AM
ksliger
Hi, ksliger.
Thank you! I haven't been able to find a part number for that anywhere. I have scoured over the latest two 977L parts manuals and nada. By chance do you or anyone have a part number?
Wed, Jul 31, 2024 9:29 AM
D8Dude
Thank you received: 28
Is this the piece that you're looking for?
 [attachment=77257]Screenshot_20240731-124806.png[/attachment]
Should look something like this;
 [attachment=77258]Screenshot_20240731-202338.png[/attachment]
Wed, Jul 31, 2024 5:44 PM
ksliger
Reply to D8Dude:
Yes, that’s it, thank you! Now the hard part is going to be finding one. If anyone knows of a scrap machine with one please let me know.
Wed, Jul 31, 2024 5:59 PM
Reply to ksliger:
Hi, ksliger.
I made one for a Cat 941 many years ago. Nope. it was NOT certified but it never failed either. I made it from heavy wall rectangular box section and put U-shaped end plates on each end. I used 5" X 2 1/2" X 1/4" wall with one edge cut out - worked for me and for the bloke (guy) i was working for at the time.
Fri, Aug 2, 2024 8:11 AM
ksliger
Hi, ksliger.
Thank you! I was just thinking to myself today how I would go about fabricating one. This is very helpful info! You don't have a picture by chance, do you?
Fri, Aug 2, 2024 9:27 AM
Reply to ksliger:
Hi, ksliger.
I wish I did but I don't.
If doing it again, I would measure the length of exposed rod when the bucket is fully raised, subtract a couple of inches to make it easier to get the finished product into place and call that the finished length. Then I'd cut a piece of box section about an inch shorter, cut one edge out of it to allow placement over the rod and weld 1/2' U-shaped plates to both ends slightly bigger than the outside dimensions of the box section and maybe 1' X1/2" flat bar to both sides all the way along the sides of the edge that you cut out for extra stiffening. Then I would drill about 1/2" clear holes near or in that flat bar to allow pins or bolts to be put right through the safety bar to prevent it falling off in the event of an accidental hit.
Those holes and pins could possibly also be used to secure the bar to the machine - - - - so that you don't lose it.
I would not use anything less than about 1/4" wall thickness for the main tube. Being that this material may not be high tensile, it might not be a bad idea to weld a length of 1/2" flat bar along the closed edge of the box section for added strength - might make it heavier but better safe than dead sorry.
On another note. the side or tailgate of a tipping truck does a pretty fair job too.
Hope this helps.
Sat, Aug 3, 2024 8:32 AM
ksliger
Hi, ksliger.
Hope this helps.
Thank you! This is very helpful!
Sat, Aug 3, 2024 7:12 PM
| Kingaroy, Queensland
