Cat 977L inspection checks
au7edd
Send a private message to au7edd
I'm going with my brother to inspect a 977L tomorrow. What things should i look for in the short time that you have during an inspection?
I always look for excessive blowback, bubbles in the radiator, oil anywhere esp.around the exhaust manifold.
Is there anyway to do a manual check on the tranny?
Wed, Dec 28, 2016 4:54 PM
Thank you received: 98
Hi, Au7edd.
There is a dipstick for the tranny, either under a floor plate or under the seat - it's been a LONNNNGGGG time since I was around one. If at all possible, check the tranny and the engine before running, then run the machine and at least drive it back and forth a bit, then check both again to see if there is any color change in the oil.
The 977Ls are a pretty robust machine.
Wed, Dec 28, 2016 5:26 PM
Thank you received: 39
Hi, Au7edd.
Only way to really check the tranny is pressure gauge readings. On site operation function is about all you can check besides fluids and leaks.
Wed, Dec 28, 2016 11:14 PM
