Cat 955C Undercarriage Question
Sasquatch
Thank you received: 5
Friend of mine has a 955C serial # 12A-1844 and is wondering if these units still used the D4 based undercarriage, as he's found a 7U D4 with a bad engine but would pick it up for the tracks if they'd fit - aside from the 7U chains likely being shorter than the 955 used but parts is still parts.  From the reading I've done to this point, I believe the change to D6 sized U/C didn't happen until the 955E model at #12A-5793, but wanted to get confirmation on this from people who would actually have experience with these machines, as I don't have any of my own in this department.  Thanks in advance!
Fri, Nov 25, 2022 8:43 AM
Change at 12A-5793 is correct.
Fri, Nov 25, 2022 9:01 AM
Sasquatch
Thank you for the help OM, I'll pass the info along [img]/media/kunena/emoticons/smile.gif[/img]
Fri, Nov 25, 2022 9:12 PM
