Cat 955 12a fluid specs
Showing 1 to 6 of 6 results
ShawnP
Send a private message to ShawnP
Does anyone have a pdf or a quick link to the 12a fluid specs (oil, final drive, hydraulics etc)
Fri, Apr 5, 2019 10:07 PM
old-iron-habit
[quote="ShawnP"]Does anyone have a pdf or a quick link to the 12a fluid specs (oil, final drive, hydraulics etc)
Thanks[/quote]
I am not sure about 12A in particular but didn't many of the 955 machines used the same oil in the engine, hydraulics, transmission, steering clutches, and maybe finals. It was supposed to be the 'need to carry only one oil' solution. Someone should be along to either confirm or straighten me out.
Mon, Apr 8, 2019 2:21 PM
Reply to old-iron-habit:
Thanks[/quote]
Engine-30W diesel oil or 15W-40
Transmission-30W drive train oil or 10w hyd trans oil below 32 deg.
Final Drives-50W gear oil or 80W-90 gear oil
Hydraulics-10W hydraulic or AW32 hyd oil
Mon, Apr 8, 2019 11:30 PM
[quote="Rome K/G"]Engine-30W diesel oil or 15W-40
Hydraulics-10W hydraulic or AW32 hyd oil[/quote]
Rome--wouldn't that be 50w diesel oil in the finals?? Thats what my 941B calls for
Tue, Apr 9, 2019 2:39 AM
Reply to dpendzic:
No, Cat has 50W transmission/drive train oil and 50W final drive oil. I have used the trans/drive train for years with excellent wear reduction.
Tue, Apr 9, 2019 3:06 AM
Thanks--I'll have to look into that--perhaps i should switch? I have power shift and wet steering clutches so i switched to the TO4 oils in them
Tue, Apr 9, 2019 3:50 AM
Reply to dpendzic:
The Cat 30W transmission/drive train oil works very good with steering clutch systems, allot smoother and no chatter with the clutches.
Tue, Apr 9, 2019 4:06 AM
