Cat 955 12A
Cat 955 12A
Showing 1 to 10 of 11 results
ShawnP
Send a private message to ShawnP
What type of hydraulic pump is in the CAT 955 12A? I believe it’s a Vickers Vane. I just don’t know what model
Mon, May 4, 2020 2:07 AM
No s/n = no answer
Mon, May 4, 2020 3:49 AM
ShawnP
No s/n = no answer
The SN is 12a539
Mon, May 4, 2020 5:28 AM
Reply to ShawnP:
The SN is 12a539
Uses a Cat #5H3422 pump which is a Vickers/Eaton #V400-28-23A11S55LH
Mon, May 4, 2020 6:45 AM
ShawnP
After looking into it a little further, I found what appears to be a U-Joint that connects to motor to the hydraulic pump has broken. What’s the best way to access this joint to replace it?
Mon, May 4, 2020 9:22 AM
Thank you received: 95
Reply to ShawnP:
Hi,
you can get to the U/J by removing the front belly plate-- the joint is right there to work on.
There is a removable front plate on the main frame that lets you get in and access the hyd. pump if needed.
Scans may help.
Mon, May 4, 2020 11:19 AM
Reply to edb:
Hi,
Scans may help.
Hopefully the center section, yoke and flange are not destroyed and it's just the u-joints that need replacement.
Takes either 2 #UJ870 (outside lock ring type) or 2 #UJ861 (inside lock ring type) universal joints.
Mon, May 4, 2020 12:02 PM
Mike Meyer
Why is it so hard for guest members to use some manners and say please and thankyou every now and then when expecting expert technical support free of charge from this Club, you can't get this info from your Cat Dealer that Old Magnet and EDB and other good members are uploading every day.
When someone does something for me for free I can't thank them enough, my new policy here is no please or thankyou from guest members, I'm not interested in trying to help. We are going broke and things need to change.
Mon, May 4, 2020 5:07 PM
ShawnP
Reply to Mike Meyer:
Thank you guys for your wealth of knowledge. As someone who doesn’t have a background in heavy equipment, you guys are a great resource.
Mon, May 4, 2020 7:30 PM
ShawnP
Reply to ShawnP:
Unfortunately one of the sides on the yoke is damaged. I’ll have to pull the belly pan and try to find a replacement yoke.
Shawnp
Mon, May 4, 2020 8:16 PM
ShawnP
Reply to ShawnP:
Shawnp
Hey guys, I wanted to share an update with you guys. We were able to get the U-Joint out of the 955. Thanks to your help, it was a fairly straight forward process. If it’s not too much trouble, could someone confirm that the broken motor side yoke part #9H3768? Thanks in advance guys!
Shawnp
Tue, May 5, 2020 7:42 AM
