Cat 951C Water Pump Rebuild
Showing 1 to 7 of 7 results
hdroadkingc
Send a private message to hdroadkingc
I need a little help with a water pump rebuild. I have removed the water pump from the machine and have the impeller off. How do I get the shaft out of the housing without breaking anything. Any help is appreciated as well as pictures. My manual dont have anything as far as rebuilding the water pump.
Tue, Aug 16, 2011 8:10 AM
Aphonopelma
Send a private message to Aphonopelma
I rebuilt mine last fall. There is a seal and ceramic disc under the impeller, mine were shot so I just tapped the shaft out the back with a hammer. Be careful when you put the new seals and washer back on the shaft, I broke 2 of those ceramic washers before I got it right.
Scott
1975 951C
Tue, Aug 16, 2011 9:21 AM
Aphonopelma
Reply to Aphonopelma:
Forgot to say the exploded view is on P23 of the service manual (Disassemly & Assembly section) and P48 of the parts book.
If you don't have the manuals let me know and I'll photocopy the pages for you.
Scott
1975 951C
Tue, Aug 16, 2011 9:31 AM
hdroadkingc
I will look at my book when I get home this afternoon. Are you saying once the impeller is off, you can tap the shaft out the back of the housing?
Tue, Aug 16, 2011 10:54 PM
hdroadkingc
Reply to hdroadkingc:
Can someone tell me if a water pump with a part # 6N8413 will fit my engine. My 951C has a serial # 69H4866 with the 3304 engine. I found a new pump for a good price if it will fit.
Wed, Aug 17, 2011 8:15 AM
Aphonopelma
Yes you can tap the shaft out through the back, high odds of the seals & ceramic washer being damaged in the process but they're likely shot anyway. Good idea to replace them during the rebuild. I'll look to see if I took any pictures of my rebuild tonight.
Edit: Sorry I didn't take any pictures of the pump rebuild.
Scott
1975 951C
Thu, Aug 18, 2011 2:30 AM
Thank you received: 46
I tried.....but appears 6N8413 is a housing only number??
Looked up 69H4866 in my 48V 3204 parts book and it states "see vehicle book" at 69H3703-up which I don't have. What is shown are pumps with a 2Pxxx part number.
Thu, Aug 18, 2011 10:18 AM
hdroadkingc
That's what I was needing to know. Thanks.
Thu, Aug 18, 2011 6:37 PM
