Cat 943 Oil leakage under injection pump
uisum
Send a private message to uisum
Hello to all .
I noticed an oil leak immediately under the ignition pump. What could it be ?
I don't want to take everything apart.
I attach images ..
[attachment=55810]pump3.jpg[/attachment]
[attachment=55811]pump2.jpg[/attachment]
Tue, Oct 29, 2019 9:25 PM
Thank you received: 60
Gasket between the injection pump and governor leaking?
Tue, Oct 29, 2019 11:43 PM
uisum
Hello.
does not lose from the pump.
only from below as the image shows
Tue, Oct 29, 2019 11:58 PM
Reply to uisum:
Hello.
What is the engine serial number?
Wed, Oct 30, 2019 2:09 AM
uisum
I don't have any other serials now
[attachment=55812]IMG_20190920_101359[1].jpg[/attachment]
Wed, Oct 30, 2019 2:48 AM
Reply to uisum:
That tag shows the engine s/n 45V61187.
There is a support bracket under the governor housing that supplies engine oil to the servo valve in the governor, the governor itself and I believe the injection pump as well. There are o-ring seals between the engine block and the support bracket plus o-ring seals to the bottom of the governor housing. Probably one or more of those o-rings that are leaking.
Wed, Oct 30, 2019 4:50 AM
uisum
[quote="Old Magnet"]That tag shows the engine s/n 45V61187.
There is a support bracket under the governor housing that supplies engine oil to the servo valve in the governor, the governor itself and I believe the injection pump as well. There are o-ring seals between the engine block and the support bracket plus o-ring seals to the bottom of the governor housing. Probably one or more of those o-rings that are leaking.[/quote]
OK
so I need to disassemble the pump I think .. 😞(
Wed, Oct 30, 2019 10:56 AM
Reply to uisum:
OK
No, you don't need to disassemble the pump. You need to check the support bracket connections under the governor section.
Wed, Oct 30, 2019 12:11 PM
uisum
ok
do you have a pattern?
thanks a lot
Wed, Oct 30, 2019 12:55 PM
