cat 941 tripping breaker while heating glow plugs
Showing 1 to 10 of 34 results
wlf89
Send a private message to wlf89
tried to crank the 941 70h617 the other day when it was around 45-50 degree for the first time in few months. after holding the switch to heat for id guess 45-60secs the breaker tripped, waited a little while and tried it again and tripped again, finally got it warm enough to crank on the third try. anyone know what would cause this to happen? short somewhere?
Sat, Dec 10, 2016 9:32 AM
Thank you received: 50
Usually or at least preferred is to have the glow plugs wired through the ammeter so you can see what is going on. Yes you probably have a short, either in the glow plugs or in the harness and wiring, also check the solenoid. Glow plugs should draw about 5-7 amps each.
Sat, Dec 10, 2016 10:11 AM
wlf89
yes the meter goes to around -30 when i turn the glow plugs on, ill give it a look and see if i can find anything
Sat, Dec 10, 2016 6:41 PM
catsilver
Reply to wlf89:
Disconnect one plug at a time and re-check the meter to see which one is faulty.
Sat, Dec 10, 2016 8:03 PM
Reply to wlf89:
30 amps may be normal--mine goes to around that when I turn mine on
Sat, Dec 10, 2016 8:07 PM
wlf89
Reply to dpendzic:
30 is normal for all 4 to be working
Sat, Dec 10, 2016 9:56 PM
tctractors
Reply to wlf89:
The heater plugs on a 941 (4 cylinder) should draw 5 amps per plug = 20 amps, if your fuse trips look at the heater rail wire for the fault.
tctractors
Sun, Dec 11, 2016 1:59 AM
wlf89
Reply to tctractors:
tctractors
ok i will check the wires when i get time but it has always read 30 when all 4 was working, but have ever used it in winter months and had to heat that long
Sun, Dec 11, 2016 2:33 AM
tctractors
Reply to wlf89:
Unless you have a 6 cylinder engine in your 941??? that will draw 30 amps, lets stick to the standard spec of a 4 cylinder 330C or 3304 as in the 941B you will only draw 20 amps, it could be dirt or crud stacked up around the plugs that is causing you pain, but the usual issue is a faulty wire leading onto the plug, the heater wire rail is a low cost item to replace Non OE or Classic Part (CAT), if you wanted to test your heater plugs, they are best removed and tested with a Battery Charger 12 or 24 volt set on low output, it is safer to use 12 volt as it will work and you will have less chance of harming yourself, you don't need to see them glow red just get warm enough to smoke, if it's -20 deg outside it will still only draw 20 amps on good plugs as the plugs don't know it's really cold.
best of luck tctractors
Sun, Dec 11, 2016 4:07 AM
wlf89
visually i didnt see nothing wrong with none of the wires that i could see. the amp gauge is going to just shy of 30, its a 60 amp gauge so kinda harder to read than stock 30 amp one the manual shows. with just one plug hooked up it is between 0and10 like it should be but with all 4 it goes to 30 so maybe the gauge isnt reading just right. anyway do yall think the problem could be in the actual breaker? i cranked it yesterday, didnt time how long i had the plugs on but it didnt throw the breaker and the dozer cranked though it could have used the plugs a few more seconds because it didnt crank smooth.
Mon, Dec 12, 2016 6:27 PM
sdmuleman
Send a private message to sdmuleman
Reply to wlf89:
Could also be a bad breaker. How much of a pain in the rear/cost is it to replace? If there's nothing obviously wrong wire the wiring I would try that next. Make sure you check all of the wiring though, it's always the hard to get to spot where it rubs.
30A may be a bit more than expected, but there's also a lot of room for error in the ampmeter and in reading it.
Mon, Dec 12, 2016 10:24 PM
