cat 941 runaway when cranked
Showing 21 to 25 of 25 results
3
bluox
Thank you received: 5
At this point you should time the pump and remove it and send it to the pump shop.
You have no idea what taking these pumps apart does and what tools it takes to time the induvial injection pumps.
800 bucks is not that bad a price.
Bob
Tue, Nov 4, 2025 10:50 PM
wlf89
Send a private message to wlf89
you are probly right, what do i have to time before removing the pump, do i just put #1 cylinder on tdc on compression stroke and then just unbolt the pump or is there more to it?
Tue, Nov 4, 2025 10:59 PM
Thank you received: 46
yes set 1 on tdc. make some alignment marks pump to engine case before you undo the pump bolts. this helps when it come to putting it back together.
disconnect the battery so it cant get cranked over accidentally.
the procedure should be in the service reference.
and it will be in the service book for the engine itself. cat engines where used in multiple applications. they had slightly different versions depending on application
Wed, Nov 5, 2025 6:32 AM
bluox
Reply to wlf89:
The shops I deal with usually send the pump back timed on #1.
So look above or below the starter for a plug in the flywheel housing, It should say 1 4 TC.
Need a 3/8 by2 1/2 bolt in the hole and turn motor in running direction while pushing bolt in till bolt goes in hole in flywheel.
If your motor has a case vent on front of valve cover take that off and you should be able to see #1 rocker arms.
If both are loose your good ,if not pull bolt out and make 1 more turn.
Now pull pump off and note which way the drive tang is marked and put pump back on that way.
Good luck
Bob
Wed, Nov 5, 2025 3:05 PM
take photos that helps remember how it went together.
Thu, Nov 6, 2025 6:31 AM
3
