cat 941 runaway when cranked
Showing 1 to 10 of 25 results
wlf89
Send a private message to wlf89
ran my 941 yesterday for 3or so hours and it ran fine and turned off fine, cranked it this morning and soon as it cranked it ran away and i had to pop the intake cover off and smoother it.
all of the linkage is moving but i feel like the lever is not pushing forward into the off position as much as it has been.
maybe something inside the governor has broke?
Thu, Oct 23, 2025 8:00 PM
Thank you received: 108
Hi, wlf89.
Does it feel like there is a distinct 'click', going through an extra resistance, when you move the throttle lever into or out of the stop position? Also, does it still have the full travel?
Like you, I would guess that the issue is inside the governor. But I'm not a mechanic, just a long-time-but-now-retired-and-LUVVIN'-it EX-operator.
Thu, Oct 23, 2025 11:50 PM
wlf89
its still makes the click when going from stop and run but the lever likes half inch from going all the way forward and feel like it used to move further forward buts it one of those things never paid much attention to so i could be wrong
Fri, Oct 24, 2025 12:59 AM
Hi, wlf89.
Funny thing about 'gut feelings' - they often turn out to be right even more often than they turn out wrong.
I'd suggest checking your throttle linkage ALL the way through to the governor BEFORE doing anything more 'adventurous'. If memory serves me rightly, there is a panel down near the bottom of the throttle/powershift control tower that you can take off to check down there. Feel any and all pivot points to make sure none of them have restrictions, under floor included. Maybe a squirt or two of 'loose juice' on the pivot points too. Do the simple things first.
Fri, Oct 24, 2025 1:37 AM
wlf89
ive looked the linkage over pretty good hoping to find something wrong with it but it seems to be good and tight everywhere
Fri, Oct 24, 2025 1:57 AM
Hi, wlf89.
Then I think you need to check the rack movement inside the injection pump unit to see if it is moving freely as and when the throttle is moved - might need a LONG arm - or a second person - to do this.
Fri, Oct 24, 2025 3:45 AM
wlf89
if i take the rear cover off the governor housing can i see the rack then? will the cover come right off after unbolting or is there linkages or springs gonna go flying out?
this is the only pic of the pump i have on my phone
Fri, Oct 24, 2025 1:29 PM
Hi,wlf89.
I'll hafta leave it to somebody else to answer that as I am not a mechanic and have never been inside one of those governors. Hopefully, somebody with more knowledge than I have will chime in here shortly.
Fri, Oct 24, 2025 1:59 PM
Thank you received: 259
Have you been using Bio fuel in your machine? I had a similar experience, except with one of my CAT RC60 forklifts. Pump was gummed up, and functionality was inconsistent/run away etc. The CAT mechanic flushed system repeatedly with some high dollar fuel conditioner and the issue went away. Best of luck getting your machine operational. JM
Fri, Oct 24, 2025 2:51 PM
bluox
Thank you received: 12
Take this advice and hire someone who knows what they are doing to look into your problem.
Bob
Fri, Oct 24, 2025 3:05 PM
wlf89
ive always just used offroad diesel from the local oil company
Fri, Oct 24, 2025 3:50 PM
