Cat 933 Traxcavator 12a part interchange with D2 5U
mkreh23
Send a private message to mkreh23
The final drive bearings on our 933 12a went out last weekend, starting to tear everything apart, and the large final drive gear has a few chunks out of it. My question is a D2 5U gear the same? Do any of the final drive parts swap across from D2 to 933? Thanks for any advice.
Mike
Sun, Jul 24, 2011 2:20 AM
The 933 is a 11A model with lots of changes. Need a serial number to do any checking.
Sun, Jul 24, 2011 4:08 AM
gemdozer
Thank you received: 12
The 933 boulgear 1f9824 fit on 11a 1 to 3653 and d2 serie 5u 1 to 18894 use the same gear
Sun, Jul 24, 2011 4:28 AM
mkreh23
Reply to gemdozer:
I miss typed my title it is a 11A. Thanks for the info.
Mike
Sun, Jul 24, 2011 8:34 PM
mkreh23
Reply to mkreh23:
Mike
serial 11a1476
Sun, Jul 24, 2011 8:38 PM
Reply to mkreh23:
serial 11a1476
On that early a serial number most parts interchange with the D2 except the steering clutches are wider and the final drive housing is wider to accomodate the larger steering clutches. The sprocket shaft is also beefed up over the D2 version.
Sun, Jul 24, 2011 10:34 PM
