[img]http://www.acmocbb.org/ACMOC_BB/attachment.php?attachmentid=15715&d=1281315206[/img]
You can see the latch adjustment screw on the very end of the latches on the exposed pinion. You access this by removing a small cover over the pinion area on the clutch housing. Adjust each one a half turn at a time and keep them equal. You may find the whole thing's fallen off in there.😆
thank you for your help. now i will get her done.
does anybody know what eng. is in this grader.is it the 318.
the tread said i have three replies and i don't see any.
Hit your refresh button and see if it will load the whole thread again.
i think i told every body my grader was a 8t but its a 7t2424 will a 8t eng. work in my 7t cat.I have a 8t to.
The 8t use a 318 motor and the 7t use a 4600 motor and yes he should fit in.
