CAT 71D engine problem
Showing 1 to 10 of 11 results
D4Doug
Send a private message to D4Doug
I was plowing snow with my 71D Blade when a loud noise started. The glow plug on one cylinder was blown out of it's holder and air was shooting out the hole. It was just like opening the cylinder pet cock on a starting engine. I am assuming that a valve is broken on the engine and compression is coming back on the intake side. I thought I would see if anyone has had this problem before I start digging into it. Any ideas?
Fri, Jan 15, 2010 3:35 AM
the glow plug screws directly into the precombusion chamber, which has a direct connection to the cylinder. Intake valve has nothing to do with it. Clean up threads and replace if possible or maybe just plug it if you can't do anything else.
Fri, Jan 15, 2010 3:43 AM
Don't panic yet😊
What kind of noise.....just compressed air???
The glow plug is screwed into the pre-com chamber and sees combustion and compression....may just have just come unscrewed.
Now if the noise is a loud mechanical sound you may have other issues.
71D is the model, D318 is the engine.
Fri, Jan 15, 2010 3:44 AM
D4Doug
Don't panic yet😊
The noise is compressed air. Pardon my ignorance but I have not ever taken out a glow plug before. I removed the adjacent glow plug and compared the two. They look the same but I think they are both worn out. I believe the glow plugs are supposed to have an end like a bulb aren't they? The heating element on these runs throught the center to an open end. Are they hard to find?
Fri, Jan 15, 2010 5:31 AM
Walt66A
Send a private message to Walt66A
Reply to D4Doug:
The glow plugs are easy to come up with. The heating element on the end is straight and a little rounded on the end, no bulb.
Fri, Jan 15, 2010 8:24 AM
Reply to Walt66A:
Here is one source....don't know anything about them.
Part number is 3H2033....as Walt66A describes.
http://www.truckengineparts.com/search.aspx?find=glow+plugs
Fri, Jan 15, 2010 8:31 AM
D4Doug
I didn't do a good job describing the glow plugs. What I pulled out is a tube- open at the bottom with the heating element in the center. I am assuming that the glow plugs are supposed to have a solid end or cap of some kind on the bottom. Without an end, there is nothing to contain the compression. I appreciate all the advice guys. As I have said before- this is the best site to ask for help.
Fri, Jan 15, 2010 9:15 AM
Reply to D4Doug:
Yes, they should have an enclosed metal jacket, configured sorta like this picture:
Fri, Jan 15, 2010 9:47 AM
D4Doug
I got my new glow plugs from my most excellant CAT dealer (Wyoming Machinery). Now any tips on installing them? Do you use anti-sieze on the threads? Torque them in?
Sun, Jan 17, 2010 8:30 AM
SJ
Send a private message to SJ
Reply to D4Doug:
Yes put a little anti seize on them and the Cat owners manual says torque them to 10-12 lbs.
Sun, Jan 17, 2010 6:45 PM
D4Doug
Reply to SJ:
Thanks to all, especially SJ and Old Magnet.
Sun, Jan 17, 2010 10:30 PM
