cat 70 scraper
cat 70 scraper
Showing 1 to 10 of 17 results
Doug Swenson
Send a private message to Doug Swenson
Does anyone know what a cat 70 scraper weighs😕
Thu, Dec 4, 2008 6:40 AM
rusted
Send a private message to rusted
According to the cat performance handbook the 8C series #70 weighs 8527lbs, and the 3W series #70 weighs 9140lbs.
Thu, Dec 4, 2008 7:01 AM
OzDozer
Reply to rusted:
It looks like the CPH is way out on those figures, as is common in the CPH, which is riddled with errors and typos, particularly when it comes to info on older items.
The 8C series, released in early 1947, weighed 17,500 lbs, and was fitted with 16.00x20 front tires and 18.00x24 rears.
In 1951, the 3W series appeared, with 16.00x24 front tires and 21.00x24 rears as standard, and was quoted at 18,800lbs basic weight.
The option of smaller size tires was still available.
In 1952, the bowl was extended from 8.7yds stuck/11yds heaped to 10.2yds struck/13yds heaped, and the weight went to 19,920lb.
In addition, 10" top extensions were available for light material, and these would have added a few hundred lbs again.
Thu, Dec 4, 2008 10:23 AM
Doug Swenson
Reply to OzDozer:
OzDozer, Were do I find the serial number on a cat 70 or 80? On the 70 I found a plate with a stamping of 4F 2164 and on a cat 80 I found a 5W 86 can you tell me what year they are? or do I even have the serial numbers? Thanks Doug
Sun, Dec 7, 2008 2:39 AM
OzDozer
Reply to Doug Swenson:
Doug - I don't have any information on S/N tag location for the #70. However, the 4F 2164 number isn't the S/N, it's a casting number of the part that it's on. The S/No's of the #70 commence with a prefix of 8C or 3W.
The number you found on the #80, 5W 86 is the S/N. This ID's it as a later series, improved #80, with a capacity of 15yds struck/20yds heaped.
This 5W model was built from 1950 to 1955, weighs 26,350lbs .. and the 5W 86 S/N identifies it as a 1950 year of production.
If you found the tag or S/N on the 80, the #70 tag will be in a very similar position. The usual position for S/N tags on towed scrapers is on the goose neck or swan neck, between or just above the wheels .. or on the rear face of the bowl somewhere in front of, or between the rear tires.
Sun, Dec 7, 2008 6:30 AM
Thank you received: 52
Reply to OzDozer:
The 4F2164 number is the actual part number for the Name Plate on the #70 model 8C1.
Appears to be unique to that model.
Sun, Dec 7, 2008 8:35 AM
Kelly
Reply to rusted:
rusted,
Old buddy could you have read the wrong line, giving the weight in "kg" Instead of lbs?
Depending on the when the 70 scraper was build, early ones had the S/N number on the right side of the goose neck (Drift beam) just under the top sheave blocks, later it was on the right side of the bowl, behind the end of apron arm…effective with 3W5367.
Kelly
Sun, Dec 7, 2008 12:09 PM
Doug Swenson
Reply to Kelly:
rusted,
Kelly
We cannot find a tag on the 70 but it has that cat 70 name plate on it with the part number on it that OM stated. It has 20 inch rubber on the front and 24 inch rubber on the rear, any thoughts on possibly knowing or guessing the year and what it holds for yards? Doug
Mon, Dec 8, 2008 9:38 AM
Doug Swenson
This 70 cat is the one Helifixer has listed with Photos.
Mon, Dec 8, 2008 9:46 AM
I don't have break down by years but I would guess early model prior to serial number 1431 when that same name tag part number changed to a 6F6424
Mon, Dec 8, 2008 10:59 AM
gary in CA
Thank you received: 8
I always wondered where our old #70 ended up.I heard it was headed back towards the midwest somewhere.My book has serial #8C1039 in but not sure if was ours or not.Another parts book I have that I got on EBAY has 3W6241 written in it and that he bought it new in 1957 and paid $12,715.Anyway heres a picture of old #70.It moved a lot of dirt.
Mon, Dec 8, 2008 11:46 AM
