Cat. 60 tag
Cat. 60 tag
Showing 1 to 9 of 9 results
catmandan
Send a private message to catmandan
I am looking to buy a 1926? Caterpillar 60. The brass plate with the serial number is missing(I assume its on the side of the seat like the later ones). Is there any other numbers on the machine to go by to find out the year? If I do find a serial number, is there a source for getting a brass plate or tag? Thanks. Dan.
Thu, May 16, 2013 3:51 AM
4tcompost
Send a private message to 4tcompost
There should be another brass tag with the ser.# on the case about a foot or so above the drawbar on the right side. Good Luck, ROY
Thu, May 16, 2013 10:21 AM
catmandan
Reply to 4tcompost:
Thanks, Roy. I have a 1928 cat 60, I can't find a tag above the draw bar. I'll keep looking.
Fri, May 17, 2013 3:35 AM
Paul L.
Send a private message to Paul L.
Reply to catmandan:
My 60 has a serial # stamped on the front right side of the engine block. Paul
Fri, May 17, 2013 5:25 AM
willwingo
Thank you received: 7
Reply to Paul L.:
In addition to the areas listed above, Sixty's were stamped on the front, outside of the right frame rail and on the flywheel.
Fri, May 17, 2013 7:19 AM
4tcompost
Reply to willwingo:
PHILDIRT, what area of the flywheel would the ser# be? thanks, ROY
Sat, May 18, 2013 9:14 AM
catmandan
Reply to Paul L.:
Thanks Paul, Still haven't found a #. I'll keep looking
Sat, May 18, 2013 7:25 PM
catmandan
Reply to willwingo:
Thanks phildirt, Now I have plenty places to search. I will let you know if I find a #. Dan.
3
Sat, May 18, 2013 7:29 PM
willwingo
Reply to catmandan:
3
Here are some pictures on the frame, flywheel and engine block:
The flywheel on my tractor is actually stamped with the number twice- once horizontally as in the picture and once vertically.
Sun, May 19, 2013 7:29 AM
catmandan
Reply to willwingo:
Thanks phildirt, with the aid of pictures I did find the serial #s on my 1928 60. Now when I go to get the 1926? I can verify that the year is correct. Thanks again. catmandan.
Tue, May 21, 2013 5:03 AM
