Cat 60 Logging Cruiser
Showing 1 to 10 of 33 results
ShawnStover
Send a private message to ShawnStover
Hi All-
Just wanted to share the latest project I've been fortunate to get to work on for the Veerkamps. We acquired a Cat 60 through a trade with Ed Akin last year, and it had all of the important factory heavy duty logging parts on it. Springs, transmission cover, idlers, idler mounts, radiator, and many other factory parts were present on the machine, making a great start to a really neat project. Over the last couple of months, Jim Chapman and I have begun quite the transformation on the old girl. We started by removing the engine, tearing it down to the last nut and bolt, and building her back to new again, with all of the pertinent parts. Next it was on to the chassis. This old girl was honestly used hard in her day, so repair of the swing frames, main frame rails, and crossmembers has proven to be a little more involved than we first though, but will be well worth the effort in the end. I have attached some pictures of the progress thus far, and will be adding more as we progress. The engine is 98% complete and painted, with only a few minor finishing touches needed. The rest of the tractor will go in for primer and paint tomorrow, and with any luck reassembly of the swing frames will begin on Tuesday or Wednesday.
Mon, Mar 14, 2016 7:49 AM
ShawnStover
Maybe I could have spit the pics up a little more... But basically they take you from start to finish on the engine removal, disassembly, repair and reassembly. The cylinders were all pretty bad, so they got bored out to .060 over stock, .060 over sized pistons were installed with new rings, and gapped to fit snug. The oil pump was a stock Sixty oil pump (one set of pump gears), and the loggers had a scavenge pump in them (three sets of pump gears). The scavenge pump had two smaller pump gears in them that were connected to pickup tubes that would pickup oil from the from and rear of the crankcase, in the event the Cat was on a steep hill. With this pump installed the loggers could operate on much steeper inclines with no damage to the engine. We had an engine with a scavenge pump in it, so I robbed the pump from it to use for this tractor. The housing was in pretty good shape, albeit a little corroded, but the gears were in pretty sad shape. As luck would have it the main pump gears are the same as a stock pump, so I replaced those from another good pump. The smaller pump gears were were able to find from a gear supply house, as they were a pretty standard size. The pictures inside the crankcase show the new pickup tubes installed and the new three part scavenge pump installed on the bottom. We stripped the block completely down and sandblasted it to begin reassembly. The crank and bearings were all pretty good, and with a little shim adjustment went back together well. I filed down all of the timing gears in front, just to get years of wear and sharp edges cleaned up again to run nice and quiet. The water pump that was on the Sixty was actually an older style Best water pump, so an era correct water pump was substituted and the Best pump was put away for safe keeping! We reassembled the engine to make sure everything fit well and fit all of the rods to the crank. For painting, we removed number 2 and 3 cylinders and heads so we could make sure to get paint on all surfaces. It took me a whole day to just to get everything set up in the booth and cleaned and masked, but I was able to prime and paint everything all at once, which made it nice for reassembly. Once the two cylinders and heads were reinstalled, the new pushrod tubes we made were polished and put back in place, then the pushrods and rockers were installed and valves adjusted. Once the engine assembly was done, it was onto the chassis. Breaking the tracks proved to be a chore. The master pins told me they didn't want to come out, but with a lot of heat and a little hydraulic persuasion, we were able to convince them otherwise!! From breaking track to priming all of the frame parts, it has been a tough 3 weeks or so but every minute has been worth it to me. Now that the post is finally started I will update it more often and hopefully have a finished product to show off soon!
Mon, Mar 14, 2016 8:14 AM
Thank you received: 140
Reply to ShawnStover:
Hi, Shawn Stover.
Great stuff and thanks for taking us along on the ride. Lookin' good. Isn't it amazing how little things keep poking their heads up to make a job like that even harder - and more interesting.?
Mon, Mar 14, 2016 8:32 AM
JasonPayneCrawlers
Hi, Shawn Stover.
Very cool. Looks great:whoo: Keep up the great work
Mon, Mar 14, 2016 9:12 AM
7upuller
Reply to JasonPayneCrawlers:
Hey Shawn,
Who is the last picture of? Guy looks like he is enjoying the Paint Fumes... Lol
Good work. Looks nice.
Glen
Mon, Mar 14, 2016 9:48 AM
Great Job! Pic #36 reminds me of Shilo Ranch from the show The Virginian.
Gary
Mon, Mar 14, 2016 9:49 AM
Mike Meyer
Thank you received: 6
Thanks for sharing the story with lots of good photo's, having the right equipment makes a tough job a lot easier, keep up the good work, she will look great when you are finished.
Mike
Mon, Mar 14, 2016 9:52 AM
Oil Slick
Reply to Mike Meyer:
Mike
Awesome work! Look forward to the rest of story :usa2:
Mon, Mar 14, 2016 10:54 AM
Moulding
Reply to Oil Slick:
Wow, nice attention to detail ! I can't wait to see the rest of the build . I wonder if you are running the high altitude heads , I haven't heard one of them running hard yet . Looking fantastic, you can have all the tools and equipment in the world but it won't turn out without knowledgable and dedicated men like your self . Thanks for the post Shawn !
Mon, Mar 14, 2016 11:44 AM
D6 Pete
Reply to Moulding:
Wonderfull job boys! ,,,I look forward to calling in to see you all again , hopefully later in year ...do you think you will do the cruiser hood ,like some had?? Regards pete.[attachment=34317]BEST Cruiser 001.jpg[/attachment]
Mon, Mar 14, 2016 2:22 PM
chriscokid
Reply to D6 Pete:
Looks real good Shawn, its a good thing you have Jim there to keep you "grounded". You know how those pilots always have their heads in the clouds..LOL
Anyway, did you have to do any work on the transmission and finals?
Thanks for posting and sharing with the rest of us how the professionals do it.
Mon, Mar 14, 2016 6:30 PM
