Cat 60 final drives
Cat 60 final drives
Showing 1 to 7 of 7 results
catmandan
Send a private message to catmandan
The packing glands or seals in the final drives on my 60 have substantial leaks. I there a method to repair the final drives without tearing them apart? Would it work to pump grease in them instead replacing the glands?
Fri, Jul 15, 2016 7:07 PM
BobPV15
Send a private message to BobPV15
If you what to try a grease I would use corn head grease it is a semi-fluid grease and can be used in low speed gear boxes. It is available from John Deere.
Mon, Jul 18, 2016 7:28 AM
X2.
Corn head grease is the first stop here for any gear box after the seals no longer reliably keep oil in unless the bearings are also going out or the leakage would be a problem. I cannot see any downside to it for most things. I know of several examples of the OEM recommending draining the gear lube and replacing with corn head grease due to the history of leaks in a specific gearbox.
Last stop before failure is thick grease like #2 "gun" grease. That can eventually thicken up and track out so no new grease gets on the moving parts as they rotate. Definitely a last ditch effort at that point.
Mon, Jul 18, 2016 10:18 AM
7upuller
X2.
Hey CatManDan,
I'm not an expert, but I think I remember the seals can be tightened on a 60 somewhat. Did you follow the owners manual for tightening procedures?
Glen
Mon, Jul 18, 2016 10:26 AM
catmandan
Reply to BobPV15:
I will try the corn head grease. Thanks for the info.
Tue, Jul 19, 2016 8:13 AM
catmandan
Reply to 7upuller:
Hey CatManDan,
Glen
[quote="7upuller"]Hey CatManDan,
Glen[/quote]
I looked at the manual. You are right the seals can be tightened. I will see if I can make it work. I have Bob's info on the grease I can also use if needed. Thanks for the info.
Tue, Jul 19, 2016 8:18 AM
chriscokid
Reply to catmandan:
Glen[/quote]
they adjust just like a thirty.
There are four packing nuts (a stud with a nut on it) located around the drive sprocket. tighten them evenly but do not over tighten, a slight leak is ok.
Wed, Jul 20, 2016 1:24 AM
catmandan
Reply to chriscokid:
[quote="chriscokid"]they adjust just like a thirty.
There are four packing nuts (a stud with a nut on it) located around the drive sprocket. tighten them evenly but do not over tighten, a slight leak is ok.[/quote]
Hi Eric. Thanks for the info. Dan.
Fri, Jul 22, 2016 6:17 PM
