Cat 3306 PC Injector Cup Gasket Question
Showing 1 to 10 of 14 results
waltini
Send a private message to waltini
Hi
I have a cat 3306 PC engine serial no. 66D01651 in a boat. I am currently doing an in frame overhaul after losing coolant into the sump. I have sent the head away to be cleaned/serviced. Since then I have read about keeping the cup/injector/washer together and noting which cylinder they came from.
What I can't find is why there are three different size gaskets and when to use which one? I am starting to panic as I dropped the head off at a shop which mainly deals with car heads. He said he had seen the type of head before a long time ago, but do I need to ring him and ask him to keep the injectors separate or can I sort it out when the head goes back on the engine?
Sat, Feb 29, 2020 1:21 PM
Thank you received: 45
The different thickness gaskets are used to locate the glow plug so that they don't interfere with the injection lines.
Sat, Feb 29, 2020 2:00 PM
waltini
Thanks for the quick reply.
Sorry I am a complete novice. I looked at your diagram but I am not sure what I am looking at or what I need to measure. I have included a photo of the head, I can see the hole where the injector and glow plug must reside but at this stage I haven't removed the chamber so I don't fully understand the set up.
Sat, Feb 29, 2020 2:44 PM
Reply to waltini:
The chart is showing the top of the prechamber, indicating where the glow plug should be.
Sat, Feb 29, 2020 7:53 PM
When the precombustion chambers are reinstalled with standard copper ring seals and torqued down to spec, if the glow plug hole stops at a position in the no-go part of the circle as shown in the diagram, the glow plug will interfere with the fuel injection line when they are installed later. So a different thickness copper ring seal is selected to move the position of glow plug hole when tightened down on the thicker ring.
If a chamber tightens in and after proper torque, the glow plug hole is in the go range, you’re done, you should have no problems installing glow plugs and injectors.
It is not a good idea to reuse a copper seal. Sort of like a head gasket, crush it once and then replace it if you must disassemble it. So you start with standard thickness seals and do the first assembly. Then select a thicker seal as required to move any that are in the no-go range. Discard the ring used for the initial unsuccessful installation.
Did you pressure test the oil cooler? It would cause a lot of anguish to get your overhaul done and still have the original problem all over again. It’s a good idea to flush it out anyway and clean any scale from the coolant side.
The other thing that should be checked is liner protrusion above the block deck. Very important for a successful long lasting overhaul. You need a service manual that shows all these procedures.
On the precombustion chamber engines it is usually cheap enough to just install new injection valves, but your old ones can be checked on a test stand and reused if they perform properly.
Sat, Feb 29, 2020 8:16 PM
tctractors
No Copper Seals under combustion chambers on a 3306, the Seals are Steel made in a number of thickness sizes to set the heater plugs in the correct Zone location, the coolant leaking into your engine is most probably from the water pump and simple to fix. tctractors.
Sun, Mar 1, 2020 1:27 AM
Reply to tctractors:
Sea water raw water pump or cooling system pump. Either one should have a weep hole drain from the seal cavity. They do get plugged up at times leading to leakage into the gear drive and engine.
Sun, Mar 1, 2020 2:32 AM
waltini
Many thanks for the replies. I probably need to uninstall the injector cup assembly myself to get a better understanding of how it fits together.
The oil cleaner has been removed, checked and cleaned. The water pump also removed and checked. Whilst these were off the oil cooler hole was plugged and system pressure tested and coolant still getting into the sump. I wish it had been an easy repair.
I have bought a service manual from the States and awaiting delivery, these motors don't seem so common here in Australia.
Point taken on the liner protrusion. Whilst I am doing all the work I have a mechanic drop in weekly to check on me!
Hopefully will lift the motor this week to access the underneath. No nasty surprises so far, all bolts came out, which was fantastic given it has been in a marine environment for nearly forty years.
Sun, Mar 1, 2020 2:52 AM
tctractors
Reply to waltini:
I would tend to think you might need to re - inspect the water pump, it could well be a rot hole in a cylinder liner though, all easy enough to sort. tctractors.
Sun, Mar 1, 2020 3:56 AM
A 66D1651 is actually a D333C Industrial Engine not a true 3306 although it is a forerunner to the 3306 and is near identical to that Industrial Engine version. Marine applications are handled by the addition of various attachments.
Parts book form number is a UE070091
If everything else has been checked I would suspect liner seals as the leak culprit.
Sun, Mar 1, 2020 4:04 AM
Thank you received: 30
Hi waltini,
the following scans may help give you a better understanding of the need for glow plug /Pre-Comb chamber orientation by using different thickness washers to achieve the correct orientation area so as the glow plug and its wiring does not foul the rocker/valve cover.
Sun, Mar 1, 2020 6:57 AM
