Cat 3208 Louisville Ford truck
D6 Pete
Hello all ,, recently bought a Ford Louie, with 3208 Cat ,,, wanted to ask ,,is it possible to buy a Cat oil pressure gauge for dash ,,, mine has a ugly kpa,, gauge ,,, Cat dealer can only find new colour type ones ,,, would like to find a Cat lbs with numbers ,,, if possible .. Thanks for any help ..
Mon, Sep 16, 2019 10:23 AM
PhilC
Hello D6 Pete
I have a 1997 Louisville but it has a dirty old cummins in it๐Ÿ˜Š There are a few Cat style gauges on ebay from the USA such as this one but you will need to find one that will ship to Australia unless you have a freight forwarder.
Regards
Phil
Mon, Sep 16, 2019 3:51 PM
Reply to PhilC:
Hello D6 Pete
Regards
Phil
from my 3208 Marine Engine Parts Book, instrument panel section, is the following electric gauge shown in psi, half dial sweep, 0-60 psi range--hard to read if 60 or 80 but 60 seems correct as it goes up in 20psi increments.
Likely white dial.
5L7455 Gauge and 5L7450 Sender for said gauge.
From No 12 17K Grader and a D6C PB is 5M1065 capillary type Gauge that would have the 3 color sectors.
This P/No may go to 1W0705 which, from a One Safe Source book, shows as most common fitted to Cat machines in the1987-8 publication date era.
Page shows most Cat Machinery Gauges and applications --but, alas I cannot post a scan here.
Tue, Sep 17, 2019 8:30 AM
D6 Pete
Reply to edb:
Likely white dial.
Thankyou for replys fellows..... might wait till in USA
Tue, Sep 17, 2019 8:54 AM
