Cat 30 Wm. Bros Blade Revisited
powergiant
Send a private message to powergiant
Attached more photos.
Rear mount method.
Any thoughts on the rear spool setup out there?
Tue, May 5, 2009 1:11 AM
I am always amazed at the ingenuity of a persons vision to create something usefull out of a piece of junk laying on the scrap pile!
It did the job (lifting the blade) he designed it to do!
It was me and a show tractor I would keep it on there because it is an oddity! I am sure other people would be interested in seeing it!
Tue, May 5, 2009 5:43 PM
cr
Send a private message to cr
Thank you received: 25
Reply to drujinin:
That thing sure is intresting.
Show tractor....isn't that where you show your wife your tractor is usefull by digging in the back sand pile...err I mean helping with the landscaping.
Tue, May 5, 2009 6:14 PM
OzDozer
Reply to cr:
The CCU is certainly unique and looks like a worm drive rear axle from an early truck, converted to a CCU. I do know that R.G. LeTourneau's first CCU was built from a Hudson car rear axle. the whole setup is well done, and very worthy of preservation.
Wed, May 6, 2009 10:36 AM
| Kingaroy, Queensland
