Cat 30 timing
Cat 30 timing
Omnitrac
Send a private message to Omnitrac
I have a Cat 30 that I had to replace the cam shaft but there is no marks on the crank gear to time the camshaft.
Can someone tell me how to set the cam.
Thanks Dennis Wilkinson
Thu, Apr 21, 2011 6:31 AM
bruce oz
Thank you received: 23
hello Omnitrac ,this may help ,not sure how much dif the 30 and 60 timing is ,bruce oz
Thu, Apr 21, 2011 7:26 AM
bruce oz
Reply to bruce oz:
hello dennis ,i 30/60 book show above but in the 30 operator book it says there are marked when built , so i would say that maybe have a chissel or a punch mark on the edge of each gear to line each up ,may need a brigth ligth to find ,sorry i am not more help than that ,bruce oz
Fri, Apr 22, 2011 4:53 AM
Thank you received: 95
Reply to bruce oz:
scan below may help as it seems the early units had different exhaust timings. If your later unit has no marks then you could use this method of setting by valve closing timing as described,by cam lobe and flywheel positions..
Fri, Apr 22, 2011 8:20 AM
