Cat 30 Mag
Cat 30 Mag
Steve A
Did this Mag ever belong on a 30 ?,If so what serial no range, I know my early ps30 has the Bosch ZR4
TIA
Fri, Mar 25, 2011 7:28 AM
chriscokid
might be a eismann not sure of the model
http://www.oldengine.org/members/diesel/Magnetos/MagData.htm
Fri, Mar 25, 2011 7:54 AM
Old Cats
Send a private message to Old Cats
Reply to chriscokid:
That might be correct on the snow cruiser/ snow special so the side curtain would not need to be opened to set the impulse.
Fri, Mar 25, 2011 7:58 AM
Paul L.
Send a private message to Paul L.
Reply to Old Cats:
From the picture angle it looks more like an IHC mag to me.
Fri, Mar 25, 2011 8:29 AM
Steve A
Reply to Paul L.:
mabye this will help, I should have posted this in the begining
Fri, Mar 25, 2011 8:39 AM
terrywelch_archive
Reply to Steve A:
While not quite, but it looks a lot like the one on our big 20, Missing the cover on the shaft end.
Terry
Fri, Mar 25, 2011 8:52 AM
Firecat
Send a private message to Firecat
Reply to terrywelch_archive:
Terry
The mag in the picture is not original to the CAT 30. Starting with Serial number S-10048 and PS-10702 CAT went to a smaller mag bracket, like the one shown in Steve's picture. CAT eliminated the hood assembly so that the Eisemann GV-4 mag was exposed. Sometime before that CAT had gone to the GV-4 mag with a hood cover, which had a large bracket to accomodate the cover. Before that (a carry over from Best) the Bosch ZR-4 with a hood was used. The replacement mag from CAT for the 30 was the Eisemann CM-4 and CT-4. Frank
Fri, Mar 25, 2011 11:38 PM
Steve A
Reply to Firecat:
Thanks Frank, That helps
I noticed the mount was smaller that my early 30 with the ZR4 and the Dog House
Sat, Mar 26, 2011 12:15 AM
Toolbox
Send a private message to Toolbox
Reply to Steve A:
Unless Eismann made a mag that parts would interchange with an IH mag, that it is a an IH. In the second picture you can see the old IHC logo between the top two plug wires.
Sat, Mar 26, 2011 10:20 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
