Cat 30 fan help
Cat 30 fan help
CodyKroeker
Send a private message to CodyKroeker
I have a cat 30 and was looking to some insight on the fan, I was running it and heard a noise so shut it off and found the fan hitting the radiator core. Removed the radiator to inspect and found everything seems tight. I can’t seem to locate the books for this and was wondering if there’s an adjustment or any kind of insight on this
Mon, Jun 17, 2024 8:50 PM
Thank you received: 214
No adjustment that I can recall -
Fan is gear driven bearings in the timing gear case.
It has been well over 50 years since I was in the fan assembly.
While you have the fan assembly open, be sure to check the friction plates, the fan sometimes slips from wearing these plates, they are held tight by a spring if memory serves.
Check that before you pull the rest of it apart.
I have seen many radiators damaged by the fans!
CTS
Mon, Jun 17, 2024 9:45 PM
Thank you received: 62
Reply to ctsnowfighter:
CTS
I had a RD 6 that rubber spacer or maybe the rubber is to help limit shock loading, anyway rubber fell apart, and fan hit the core make a big mess of it. Your 30 is about the same vintage. So maybe what is going on with yours.
Tue, Jun 18, 2024 10:14 PM
Floyd Green
Send a private message to Floyd Green
Reply to Ray54:
In reading this thread I believe I found out what that hand full of wired together rubber pre-drilled (gaskets?) are. In other words I might have just what you need. I will try to find them today. Would they be the same size as a Diesel 40? I have a 40 here to compare it to.
Wed, Jun 19, 2024 11:27 PM
Floyd Green
Reply to Floyd Green:
I found ten 3B8676 (spacers?) that matches various CAT fan blades here. Total. 7 1/4" Dia. X 1/2" thick. 8 outer holes, 6 inner holes. PM me if interested.
Wed, Jun 19, 2024 11:42 PM
CodyKroeker
I was thinking it would be a bearing failure but everything looks as it should so far not seeing anything that would have caused it to hit the radiator
Mon, Jun 24, 2024 7:51 AM
Reply to CodyKroeker:
Cody,
As I suggested, check that fiber washer/friction disc just behind the fan blades.
The fan slips over time and wears that away, changes the clearances.
Try to find a schematic of the fan assembly/parts book, etc.
CTS
Mon, Jun 24, 2024 9:08 AM
brian18a
Thank you received: 69
Cody,
CTS
There are no rubber discs on a cat 30. Just two relatively thin friction discs.
Mon, Jun 24, 2024 11:19 AM
CodyKroeker
Cody,
CTS
That’s where I’m going next just wanted to share some pictures…I wanted to check the bearings aswell just to have peace of mind and not go into it twice…I’m looking for the books my grandpa had on it to find the diagram for it but I’m still looking for them. I feel like there should be a bit holding spring tension on there but not sure there wasn’t one there when I disassembled it
Mon, Jun 24, 2024 8:02 PM
