Cat 30 Belt Pulley.
Cat 30 Belt Pulley.
Dandy Dave
Send a private message to Dandy Dave
A buddy of mine has a Cat 30 and recently acquired a belt pulley for it. The tractor has an 1-1/8, 6 spline inside the case. The belt pulley has 1-5/8ths 10 spline. Anyone know where to get a coupling? Or any ideas to get it hooked up and working? Seems odd that Cat way back when would have done that.
Fri, May 1, 2020 8:01 PM
STEPHEN
Check Hub City for their splined couplings. Get one of each, cut in half, prep in lathe & weld together.
Fri, May 1, 2020 8:18 PM
Dandy Dave
Reply to STEPHEN:
OK, Thanks.
Sat, May 2, 2020 5:38 AM
Dandy Dave
Reply to Dandy Dave:
OK, Thanks.
The website there gives 0 result for a "splined coupling", Do they call it something else?
Sat, May 2, 2020 6:00 AM
STEPHEN
Really? I will check it out, that is where I used to get them, but it's been a while
Sat, May 2, 2020 8:16 AM
STEPHEN
Reply to STEPHEN:
Do a web search for hub city 0332-00349
And 0332-00349.
If you can't buy direct try Baum hyd 800 227-9222
I tried looking at the online hub catalogue & gave up, I think they have been bought out.
The big one is on ebay, check it out
Sat, May 2, 2020 9:01 AM
| Kingaroy, Queensland
