Cat 225 fuel trouble
Showing 1 to 7 of 7 results
ETD66SS
Send a private message to ETD66SS
So I ran my 225 out of fuel last Saturday. I filled it up, primed it, as everything seemed fine. However, since then, I need to prime it every day I want to use it. It starts fine, but when I run it, it lacks power and gyrates when driving. If I get out and re-prime, it works fine for the rest of the day.
I will replace the fuel filter today, but I'm not sure that is the problem, because the re-prime works. If the filter was clogged, re-priming would not get me the power back.
I guess maybe I have an air leak, and the only thing I touched was the petcock valve. Maybe that is not closing all the way?
Mon, Apr 8, 2013 6:37 PM
bob
Send a private message to bob
[quote="ETD66SS"]So I ran my 225 out of fuel last Saturday. I filled it up, primed it, as everything seemed fine. However, since then, I need to prime it every day I want to use it. It starts fine, but when I run it, it lacks power and gyrates when driving. If I get out and re-prime, it works fine for the rest of the day.
I guess maybe I have an air leak, and the only thing I touched was the petcock valve. Maybe that is not closing all the way?[/quote]
Gene, take off the small fuel return line from the pump to the tank. Blow air through it untill it's clear, you should hear it with the cap off the tank.
Later Bob
Tue, Apr 9, 2013 4:36 AM
Thank you received: 32
Reply to bob:
Later Bob
the sleeve metering pumps have a problem with air being able to be trapped under the rack set housing.
At least on the 3208 you can bleed this air out by loosening the pin timing bolt--9/16" head plug/bolt on the small odd shaped housing behind the top cover over the Governor housing.
This air bubble needs to be compressed by the transfer pump pressure to get the fuel level above the plunger ports to enable the fuel to be pumped to the injectors-long crank time for engine to start.
After shutdown the pressure disipates and the trapped air expands again and again needs to be compressed for the next start to occur.
As Bob said, if the fuel return orifice in the bleed valve does not let some 9 gallons of fuel per hour return to the tank air will also build up in the pump and cause the symptoms.
Hope scan below helps you to find the bleed/pin timing plug/bolt--loosen the bolt just enough to allow the trapped air/fuel to escape.
This needs to be done anytime you run out of fuel or fit the pump to the engine or sometimes when the fuel filter is changed air is introduced from a dry/empty filter.
Tue, Apr 9, 2013 9:57 AM
Gavin84w
Reply to edb:
You will be on your way with all those suggestions, 100% on the money.
Tue, Apr 9, 2013 4:32 PM
ETD66SS
Reply to Gavin84w:
Thanks for the suggestions, I will try them next time I'm out there.
Wed, Apr 10, 2013 1:34 AM
ror235
Send a private message to ror235
Reply to ETD66SS:
I am having a very similar problem with my 235. You have to have one guy pump the primer pump and one guy crank it to get it started, once it's going it runs fine, and it will start again as long as it's been started within say an hour or two, but it will not cold start without priming. I have blown out the return line, supply line, new filters, checked to make sure all the connections in the lines are tight, starting to think it must be in the fuel pump.
Mon, Apr 22, 2013 12:40 AM
bob
Reply to ror235:
If you have blown out the fuel return line back to the tank then replace your return line fitting. If the line is clear and you can hear it bubbeling in the tank then disconnect the line at the pump and make sure fuel is comming out the fitting from the pump while running. f you have good return it will bleed the air out and solve your problem.
Later Bob
Mon, Apr 22, 2013 3:08 AM
Reply to bob:
Later Bob
the inline sleeve metering pumps suffer the same problem of air being trapped in both the governor part of the main housing and the torque spring housing on the main injection pump body.
To bleed these you have to loosen the top 7/16"AF head bolt and get the gasket to unseal to bleed most all of the air out, whilst pumping the priming pump -if fitted, of this odd shaped housing with the little electrical looking connector in it.
Scan below should help.
Mon, Apr 22, 2013 6:22 AM
