cat 22 steering clutches
Leon R
Send a private message to Leon R
I have the old cat running (engine wise) after being asleep for fifty years. I now need to get the steering clutches to operate. As of now the steering clutch levers are loose all the way to the rear with no effect on steering. I have talked to the owner who parked it at the time because of ignition problems which I found to be a bad coil in the mag. He said it was steering ok when last used before the ignition problem. There appears to be some braking effect from the foot brakes. Could someone explain why the steering clutches are not operating and what I can do to get them to, short of taking it all apart. I have read in the manual how to wash them. Would filling them with a washing agent and letting them soak for awhile help?? Also can you use diesel full as a washing agent? Thanks, Leon
Thu, May 26, 2011 9:09 AM
Steve A
Leon
I would guess that the clutch disk have swelled, adjust so you can apply pressure to open them, the adjustment in under the gear shift pattern plate, once you get things loose and exercised you will likely have to back off the adjustment
Thu, May 26, 2011 10:00 AM
Leon R
Reply to Steve A:
Leon
Thank you Steve, I will give that a try. Leon
Fri, May 27, 2011 2:57 AM
Mike Meyer
Thank you received: 6
Reply to Leon R:
I'd try diesel for sure, you have nothing to lose if those steering clutches are frozen because you don't have much horsepower on your side to help free them.😆
Get as much diesel in both sides as you can and if possible drive the tractor too, but just remember once you have them working you will need to drain the oil from the transmission and final drives as it will most likely be contaminated with the diesel weeping past the seals.
I'd also be tempted to flush those steering clutches with kerosene once I got the clutch packs slipping again, just to help clean the clutch plates and brake bands.
Good luck
Mike
Fri, May 27, 2011 3:35 AM
Reply to Mike Meyer:
Good luck
Mike
Use the search function in the upper right hand of the webpage. It'll give you probably a 100 threads on D2's with frozen steering clutches. These will tell you all the tricks to try.
Jeff
Fri, May 27, 2011 4:34 AM
Leon R
Reply to drujinin:
Jeff
I have searched and read a lot of threads about frozen/stuck steering clutches and have decided to try a method not mentioned or at least not found by my search. In the past I have used the diluted molasses method of derusting iron. I have mixed one part of BlackStrap molasses with ten parts of hot water and mixed it well and poured it in until it ran out the brake linkage access. Will let it sit for a month and then flush out with hot water and then try to wash with diesel and see what happens. Will let you know how it comes out!!!! I am sure this will generate a few comments!! Leon
Sun, May 29, 2011 7:08 AM
