Cat 22 rusted fuel tank.
Showing 1 to 10 of 25 results
GrantJ
I have my fuel tank off right now and have discovered that it is badly rusted at the outer edges where it sits in the saddle. There was some kind of fabric or rubber between the saddle and the tank, that must have absorbed enough moisture to do some pretty deep pitting. I think that there is supposed to be some type of padding between the tank and saddle, but does anyone know what it should be , so it does not cause more rust?                   Thanks Folks,  Grant.
Wed, Sep 4, 2024 10:38 AM
side-seat
Thank you received: 8
Original was a manila hemp pad similar material used in the seat cushion can't remember the correct name.
Yeah, Not a good choice though!
Probably should cut the bottom out and weld a new piece in.
Another idea although not original; is put a smaller tank inside depending on how much running you'll be doing.
Wed, Sep 4, 2024 8:14 PM
Thank you received: 101
Reply to side-seat:
Grant: Being the tightwad that I am at times, I have used remnants of tarp webbing or slightly used 2" web straps to cushion, or thin rubber belting. Something is better than nothing, and unless you advertise it, nobody would know except you. Can you use marine grade JB weld to patch up your tank, or is it too far gone? JM
Wed, Sep 4, 2024 9:47 PM
Thank you received: 24
Is that JB Weld gas-friendly, JM?
Wed, Sep 4, 2024 11:21 PM
bruce oz
Thank you received: 20
origanial it would have been asbestos sheet , i had a new bottom welded into the one did
Thu, Sep 5, 2024 3:37 AM
Reply to bruce oz:
Bruce, how did you prepare the tank for welding? I'd like to weld a new floor into mine but don't want to blow myself up. I've heard all kinds of advice so it seems there isn't just one way. This tank hasn't had significant gas in it for years - only the starting tank has had gas in it recently
Thu, Sep 5, 2024 7:50 AM
GrantJ
Reply to bruce oz:
JB Weld sells a fuel tank repair epoxy. I am going to try it tomorrow. The pin hole is less than 1/8 inch and I dont think the area around it is as bad. I will sandblast tomorrow and if the hole doesnt enlarge, I will try the JB. I suspect that asbestos was the water absorbing cloth that caused this problem. I may epoxy rubber to the area that contacts the saddle. Hopefully no water can get under the rubber. Grant.
Thu, Sep 5, 2024 7:52 AM
Thank you received: 86
Reply to GrantJ:
Welding Fuel Tanks?
Metal is porous. Steel and Iron "rust" which is a very slow "oxidation" process. Oxidation is Burning if you will, same as cutting with an oxy-acetylene torch.
Some have sucessfully welded on fuel tanks, others have not met the SAFE results, either maimed or killed.
There exists many that say it is a "SAFE" operation "IF" - the key portion being the big "IF".
Personally, I do not believe there is a "SAFE" and assured method, I vote for a Cold process.
Many will disagree, that is expected, but I would not get caught welding, cutting or grinding on a fuel tank. Confined spaces are perfect for incidents to occur.
STAY SAFE
Cts
Fri, Sep 6, 2024 4:51 AM
GrantJ
Reply to ctsnowfighter:
Welding Fuel Tanks?
STAY SAFE
Cts
I think that the JB Weld Tank Repair kit worked. I am going to use it as is , while I work out many other things on the tractor. When I have the other issues worked out, I will have the bottom of the tank re-plated. The local farm repair shop says that it is no problem. They keep CO2 flowing into the tank when welding. I would not attempt to do it myself, but these guys have done it many times before.
Grant.
Fri, Sep 6, 2024 9:25 PM
Reply to GrantJ:
Grant.
Great thanks for the update Grant, very helpful.
Sat, Sep 7, 2024 1:05 AM
Busso20
Thank you received: 12
GrantJ and Neil, on a few smaller mines sites I have worked on they do sometimes fix tanks (in emergency cases) when they don't have a replacement or time to stand the only front line machines down (exacvator normally) they would remove tank if they had no access to repair area and would run the exhaust off a toyota land cruiser (diesel vehicle) into the tank then wait I think it was 3 hours to fully fill tank with the fumes then start the repairs most of the time it was a cracks to be welded, I did find the copy of the repair site procedure and didn't realize to would be allowed on site but it was done many times. Petrol to diesel tank im guessing it would be a similar process to follow.
Sat, Sep 7, 2024 7:09 AM
