Cat 22 rear starting crank
Peter C
Send a private message to Peter C
Having never seen one but knowing it was a Caterpillar option I would guess that this one is homemade. Doesn't look like Cat quality. Any thoughts?
Pete
  [attachment=77306]IMG_E3874.JPG[/attachment][attachment=77307]IMG_E3873.JPG[/attachment][attachment=77308]IMG_E3876.JPG[/attachment][attachment=77309]IMG_E3875.JPG[/attachment]
Wed, Aug 7, 2024 11:32 AM
Thank you received: 78
Agreed, doesn't seem to match the parts catalog diagram. Still, presumably it gets the job done
Wed, Aug 7, 2024 7:11 PM
side-seat
Original CAT rear starting would have the jaw inside the transmission case and a special casting that holds the shaft with a spring to disengage.
Wed, Aug 7, 2024 8:37 PM
Peter C
Yes, now that I am home and can look at my parts manual I see what it should look like. I wonder how long of arms you would need to operate the choke and crank to start it!
Thanks for the thoughts. Now I don't feel the need to try to buy it!
Pete
Fri, Aug 9, 2024 8:03 AM
