Cat 22 pulley fit??
Cat 22 pulley fit??
tomseabee
Send a private message to tomseabee
I would like to put a pulley on a Cat 15 but can't find one specifically for that tractor. Will a Cat 22 pulley fit the big 15 (PV 5600)? Is there a cookbook on how to rebuild the soft pulley material? I was given the site of a paper pulley rebuilder that looks promising but first need to determine if it will fit.
Thanks,
Tom
Wed, Nov 7, 2007 11:01 PM
2HIGHTEN
Send a private message to 2HIGHTEN
The pulley from a pv 15 8c20, or 22 should all be the same mounting setup.
The paper pulley co that ads in antique mag and others should be able to fix you up good. Ron Meeder
Thu, Nov 8, 2007 7:46 AM
tomseabee
Reply to 2HIGHTEN:
Thanks Ron. That's what I needed to know. I appreciate the information.
Tom
Thu, Nov 8, 2007 8:17 AM
