Cat 22 murphys law
Cat 22 murphys law
Showing 1 to 10 of 11 results
sbybee
Send a private message to sbybee
Why is it every time I decide to sell something it quits running? I have a couple that wanted my 22 and I figured it was time. This cat has run great from the day I found it in a barn and has always started quick (electric start) for two years or more and the morning I make the decision, not easy, she won't start. Took the mag down to the shop I use in Fresno and there was a problem he fixed and recharged the magnet. Put it in and still won't go, pulled valve cover and rechecked marks and something didn't look right, back to shop and he found gear marks off three teeth and could not believe I hadn't taken it apart. I hadn't so he will figure it out. Hope nothing major broken, Oh well. Then the D2 sounds like its running on two injectors. I think I'll work on a lawnmower for a while steve
d2, 2n, 8n, 4000, cub cadet 169, massey compact, home made tractor, and more
Exact center of California
Sat, Mar 5, 2016 10:20 PM
ronm
Just wait til you get it in front of a crowd...a tractor or engine will never fail to start until you take it to a show, or heaven forbid kill it hooked to the pulling sled in front of hundreds of people...😛
Sat, Mar 5, 2016 10:45 PM
Dozerman51
Reply to ronm:
My theory is if you kill it hooked to the pulling sled, the tractor is telling you " Enough of this s... . I did my part all these years, I want to live a quiet life of tractor shows only". LOL?:usa2:
Sun, Mar 6, 2016 12:41 AM
Thank you received: 131
Reply to Dozerman51:
Hi, RonM and Dozerman51.
MY theory if you kill it while pulling a sled is that you weren't paying enough attention to what the tractor was telling you about its relationship to the load.
Just my 0.02. (But what would I know? I'm just a 'pore. dumb bulldozer operator' in only the (5)2nd year of his apprenticeship.)
Sun, Mar 6, 2016 3:36 AM
ronm
Yeah, like you've never killed an engine, Deas...👋
Sun, Mar 6, 2016 9:48 AM
22runner
Send a private message to 22runner
Reply to ronm:
Steve ........ Did you get it running and make the sale?: If not let me know.
Tom 22runner
Sun, Mar 6, 2016 11:59 AM
Reply to 22runner:
Tom 22runner
Hi, RonM.
Yes, I have killed an engine - or even 2 - WHEN I wasn't paying attention. Similar situation to pretty much ALL traffic accidents being caused by 'mechanical failure' - - - - - the 'loose nut' holding the steering wheel. 😄
Sun, Mar 6, 2016 12:26 PM
ronm
Hi, RonM.
Well, the human tendency in a tractor pull is to get every inch you can, so it happens...& something about being killed under a hard pull makes a (gas) engine not want to start right up again. This of course is more of a problem with hand-crankers...humping a JD G or D over under stress in front of a crowd is good exercise.
Funniest thing I ever saw at the pull was a JD 70 Diesel...the guy idled it down too much taking up the slack, & it kept running when he pulled the clutch. But it sounded funny, & oil started puking out of the air stack...running backwards! He put her in first to pull, but she backed up against the sled... He was totally flustered, hadn't seen the oil puking out, & kept trying to find a "forward" gear. I was working the hook, & finally told him "Shut it off Calvin, it's runnin' backwards!" He was so befuddled I had to tell him twice, he looked at me like I was crazy...finally convinced him to kill it, & it was OK when he restarted it...just a mess from the oil. Those old 2-cyl. diesels would do that with just the right combination of clutch & bouncing back on compression.
Sun, Mar 6, 2016 10:02 PM
sbybee
Reply to 22runner:
Tom 22runner
[quote="22runner"]Steve ........ Did you get it running and make the sale?: If not let me know.
Tom 22runner[/quote]
Not yet to both. The mag is still in the shop and I have a couple that say the will buy it if it runs. Hopefully next week I'll know. steve
Sun, Mar 6, 2016 10:44 PM
Reply to ronm:
Hi, RonM.
I've hadda 2T D4 do that - - - when I was too slow knocking the clutch out. Strange sounds and oil coming out of the air cleaner was enough for me. Shut it down and fire the pony up to get it running the RIGHT way again.
Some of the old 1-lung diesel tractors could be gotten running backwards when stationary by shutting the throttle down until they were almost stopped and then jerking the throttle open again. Field Marshals and Lanz tractors were 2 examples of this.
Sun, Mar 6, 2016 10:47 PM
old-iron-habit
Hi, RonM.
[quote="Deas Plant."]Hi, RonM.
Just my 0.02.[/quote]
6-71 Detroits were good for running backwards if you were in a hard pull in lower gears and pushed the clutch in to late. Happened to me once as a lad with a 100,000 lb gross of tree length pulp wood. Lucky the brakes were good to hold on the logging road hill and it started right up. Had to back down to a better spot to get going again in granny gear.
Mon, Mar 7, 2016 12:41 AM
