Cat 22 Electric Start
Showing 1 to 10 of 13 results
junkologist
Send a private message to junkologist
Does anyone have any information re; Electric starter for Cat 22? We have two 22's and are considering converting if starters can be found or fabricated. Thx
Fri, Oct 26, 2007 1:35 AM
Jon
Send a private message to Jon
You need to look at your flywheel to see if there is a ring gear on it, first.
Fri, Oct 26, 2007 8:52 AM
junkologist
Reply to Jon:
We are past that. We are looking for a source for the starter motor. Or if I can find specs or drawings I can cast and machine the nose cone. I've been told that the R2 may have had a starter. Did the 22 and R2 have the same engine? thx Scotty
Fri, Oct 26, 2007 10:19 PM
Jon
Reply to junkologist:
there are two models of the R2 the first one is identical to the 22 and is very rare uses the same starter as the 22, delco remy #736-D. The other is a gas version of the D2 uses a delco starter #1107426.
A pic of a 22 with electric start conversion.
Fri, Oct 26, 2007 10:42 PM
rgenger
Send a private message to rgenger
I bought a starter adapter plate and gear ring from some one in the club several years ago I will see if I can find the particulars
roy
Wed, Nov 28, 2007 6:01 AM
rgenger
I bought a kit from one of the club members several years ago
it includined a gear ring a adapter plate and starter moter
I will try to find out who it was
Roy
Wed, Nov 28, 2007 6:07 AM
brewzer
Reply to rgenger:
Roy
This man used to make a 22 starter kit. John Sell I have his address and E-mail. I am not sure if he would want me to publish it so E-mail me and I will give it to you. He also rebuilds 22 water pumps. Wally
Wed, Nov 28, 2007 10:35 PM
junkologist
Reply to brewzer:
Got it Wally, thx all, should get us on our way!!
Fri, Nov 30, 2007 8:09 AM
AJ.
Send a private message to AJ.
Someone posted this picture ages ago, I suppose he had no ring gear or starter hole but nevertheless he got around it and avoided knocking it off as well.
AJ 😊
Fri, Nov 30, 2007 3:02 PM
WSTUBBS
Send a private message to WSTUBBS
I have a friend who added elect start to his CAT22 and quite possibly he could help out. His Name is Doug Johnson, 5225 West Dry Creek, Healdsburg CA, 95448
Mon, Dec 3, 2007 12:44 PM
Albertagary
Send a private message to Albertagary
Reply to WSTUBBS:
I have a 736 D Delco Starter less drive for a Cat 22.It will fit 22's with a factory ring gear.My 22 had an aftermarket ring gear on flywheel so it wouldn't work.It took me two years of searching to find the right one to fit.
It was worth the search.
Gary
Mon, Dec 10, 2007 10:40 AM
