Cat 22 crank bearing clearance
Showing 1 to 6 of 6 results
Leon R
Send a private message to Leon R
I have been slowly cleaning up the new toy and will be checking the con rod and main bearing clearance but cannot find out by searching the forum what specs they should meet. I did find one thread (was for another model) that said not less than .003 and not more than .012 That seems to be quite loose to my way of thinking!! I am thinking that .003 would be max. Is that correct for a 22?? Also can not find the torque value for them as well. Thanks, Leon
Fri, Sep 17, 2010 1:25 AM
WyoCat
Babbit bearings are different than modern bearing shells. Babbitt is typically softer and likes a larger oil clearance so that the oil acts as a cushion and the babbitt absorbs any foriegn materials. I would try to get your bearing clearances somewhere between .003" and.006", but closer to .003 You will be fine if you get them within that range.
Chad Enyeart
Fri, Sep 17, 2010 2:06 AM
Leon R
Reply to WyoCat:
Thanks WyoCat, just have to find some plastiguage to cover that range of clearance. Would you happen to know what torque is required for the cap and main bolts?? Thanks again. Leon
Fri, Sep 17, 2010 11:04 AM
WyoCat
Reply to Leon R:
When I torque these old main and rod caps I use a standard torque chart for size and thread pitch. As I torque them I watch to see how close the castle nut is to lining up with the hole in the stud. Instead of over tightening a nut to line it up its better to stop early. While "technically" the nut will be slightly undertorqued it will not back off due to the cotter pin holding it in place. I have even tried different nuts on different studs to get them to be as close to torque as possible with the slot lining up. Hope this helps.
Chad Enyeart
Fri, Sep 17, 2010 8:31 PM
Leon R
Reply to WyoCat:
Thanks again Wyocat, appreciate the advice. Leon
Fri, Sep 17, 2010 8:46 PM
John from Fresno
Reply to Leon R:
If you ever have trouble getting the cotter pins holes to line up and backing off is too loose, just go to the bench grinder and grind a little off the side that bears against the cap. It will allow you to make it to the next hole.
John
Sat, Sep 18, 2010 7:30 AM
jmvmopar
Reply to John from Fresno:
John
My Cat books say to torque then TIGHTEN till the slot lines up.
Sun, Sep 19, 2010 10:05 AM
