CAT 22 Clutch Pedal
CAT 22 Clutch Pedal
Does anyone have a photo of the spring and bracket(?) that holds the clutch disengaged?
Mine is missing which makes the pedal flop back and forth which means it is riding on the throw out bearing.
Thu, Jun 27, 2019 8:51 AM
brewzer
It is exactly the same as the brake set up for locking the brake pedal down. With it missing the pedal would stay disengaged.
Thu, Jun 27, 2019 12:41 PM
D4Jim
Reply to brewzer:
Snapped this pic of a Cat 22 in front of a construction co just east of Arapahoe Nebraska Wed.
Cats Forever
Thu, Jun 27, 2019 12:59 PM
hfdzl
Reply to D4Jim:
This is what the clutch arms look like with brake pedal. The shaft goes thru the case with the RH brake pedal on the other side.
[attachment=54485]22 Master Cl and Brake Adj.jpg[/attachment]
Thu, Jun 27, 2019 3:49 PM
Reply to hfdzl:
OK, Thanks!
I'll study it some more as I have the Fuel Tank off right now and can get down close enough to study the internal linkages!
Thu, Jun 27, 2019 6:23 PM
