Cat 22 Carb Float Adjustment
lrolla
Send a private message to lrolla
This a new tractor for me so I don't know if this is a new or old problem.
When attempting to start with the choke engaged, gas starts to drip out of the carb and it floods. I've cleaned the needle valve on the carb and now I'm wondering if the float needs to be adjusted. Does anybody have the specifications on how the float should be adjusted on a Zenith carb?
Thanks,
Larry
Larry Rolla
Tue, Jun 19, 2012 12:09 AM
[quote="lrolla"]This a new tractor for me so I don't know if this is a new or old problem.
Thanks,
Larry[/quote]
Larry,
I recall seeing a thread here on that subject. Just do a search on "carb adjustment" and you should find it.
Ray
Tue, Jun 19, 2012 12:56 AM
| Kingaroy, Queensland
