Cat 22
Peter Mercer
Send a private message to Peter Mercer
I finally purchased my grandfather's old 22. Now I have to get it home. The problem with that is that there is something stuck. It will not roll on the tracks. The tractor is in neutral because it will turn over on the hand crank. Could the brakes be stuck or the streering clutchs stuck? If so is there an easy way to correct it so it can be towed on its tracks and pushed into my garage?
Thanks, Peter
Peter Mercer
1934 Caterpillar 22 - 2F818,
1952 Willy's M38 Jeep, 1956 Farmall Cub, 1961 GMC Pick-up, 1964 Thunderbird.
St. John's, Newfoundland
Canada
Sat, Nov 29, 2008 9:35 PM
Jed
Send a private message to Jed
Sometimes the tracks get seized up from rust. Especially when sitting in the dirt for a long time. My 22 had rusted up tracks and I would go out every day and spray a little diesel fuel in the links with a weed sprayer. I would try pulling it around every week and it finally broke loose.
Sat, Nov 29, 2008 10:06 PM
JasonPayneCrawlers
Reply to Jed:
By the look of were it sits it might be the tracks or the brake bands might be stuck I had that problem on a D2. Take a hammer and see if the tracks move up and down between the idler and the sprocket, that might let you see if they are stuck.
Sun, Nov 30, 2008 10:47 AM
Jon
Send a private message to Jon
Reply to JasonPayneCrawlers:
Try hooking a chain to the top of the track just in front of the drive sproket and pulling on one side at a time.
Mon, Dec 1, 2008 12:21 AM
Catmatt
Send a private message to Catmatt
Reply to Jon:
That machine has the really neat ice Cleats! Nice find!
matt
Mon, Dec 1, 2008 4:35 AM
