Cat 212 Road Grader questions air filter
Showing 1 to 6 of 6 results
Crg169783
Send a private message to Crg169783
This machine is going to the Ukraine as part of a non profit. Currently it is at my place while we do final repairs and maintenance. I took apart the air filter to see how it looked and kinda got stuck.
I didn't want to go deeper until i had some feedback from someone who knows more.
I took off the bottom, (It was filled with oil to the line) then 2 more pieces came out. i couldn't get any more pieces or the actual air filter out.
Attached pictures of what did come out.
Are there more than one pieces inside?
How do i get the filter out?
What are the pieces called that I was able to take out?(Just for knowledge)
As always thanks for all the help, you all are amazing.
CRG
[attachment=47836]20180328_174023.jpg[/attachment][attachment=47835]20180328_174019.jpg[/attachment][attachment=47837]20180223_103630.jpg[/attachment]
Thu, Mar 29, 2018 7:06 AM
WA7OPY
Send a private message to WA7OPY
Is this your first rodeo with a oil bath air cleaner?....Wa7OPY
Thu, Mar 29, 2018 7:28 AM
old-iron-habit
[quote="Crg169783"]This machine is going to the Ukraine as part of a non profit. Currently it is at my place while we do final repairs and maintenance. I took apart the air filter to see how it looked and kinda got stuck.
CRG
[/quote]
You have the filter assembly out. It is an oil bath filter. It cleans by swirling air thru the oil. If dirty there could be a 1/2 inch of mud in the bottom of the oil. Clean it up good, fill the pan to the oil line with new 30 weight oil and put the pan back on. Probably be good for another 20 years.
Thu, Mar 29, 2018 7:58 AM
Crg169783
Reply to WA7OPY:
Ive had oil bath filters before, but most of them have a filter you can change. however i have never see one with more that one filter piece
Thu, Mar 29, 2018 8:24 AM
Crg169783
Reply to old-iron-habit:
CRG
[/quote]
So the air filter assembly is only the 2 pieces in the picture? looks like there is more up inside the housing?? Thanks
Thu, Mar 29, 2018 8:26 AM
Thank you received: 77
Reply to Crg169783:
you have all of the removable pieces out of the main housing.
Screens above those are welded in place and so not removable.
Scan below should help further on how to clean the non-removable section and housing in general.
Thu, Mar 29, 2018 9:03 AM
Crg169783
Reply to edb:
awesome thank you
Thu, Mar 29, 2018 9:30 AM
| Kingaroy, Queensland
