Cat 212 24 volt alternator
AGES CAT
Send a private message to AGES CAT
We have converted the D311 engine from the pony motor to direct electric start. The starter works great. All I am in need of is the 24 volt alternator and a compression release handle assembly which bolts to the engine. Can anyone recommend a place to purchase the alternator which will bolt up to the generator flange? Thank you.
If anyone has the compression release lever which bolts to the engine, I am in the market for it. We have the late new style engine arrangment.
Thu, Jan 24, 2013 5:40 AM
Larry
Send a private message to Larry
Ages Cat, why did you go to a 24 volt system? A 12 volt truck starter will work fine on a 311. I am using one on a 330 and it works fine, even in cold weather. Also you can get 12 volt alternators cheaper than 24 volt systems. Cheers, Larry.
Thu, Jan 24, 2013 8:42 AM
Thank you received: 62
Reply to Larry:
I have been told a Delco can be converted to 24 volt very cheaply.Was told local auto part store was selling them for less than $150 a year or so ago.
Ray
Thu, Jan 24, 2013 11:14 PM
Link to another thread about your conversion. http://www.acmoc.org/bb/showthread.php?15291-24-volt-alterantor-conversions&highlight=alternator+conversion
If you have the old generator, probably the simplest conversion is to install a pulley on the back of the generator shaft (may take a new, longer shaft and use a belt drive alternator mounted on top of it.
Fri, Jan 25, 2013 2:09 AM
