Cat 2 ton need help/info on engine
Showing 1 to 10 of 10 results
country
Send a private message to country
I have a really nice 2 ton cat, with original pressed pads, crossbar steering, air cleaner in tact, etc
it sat for 3 years inside my barn and now the engine is stuck
I pulled the pan, put some pressure on the crank with a bottle jack and still nothing. looking up inside #2 cylinder, I can see soem rust on the cylinder walls. I filled the cylinders with diesel fuel and will try to soak it out.
One of my questions is, if I have to pull the head, where can I get a head gasket set? How about piston rings, assuming they are standard.
thanks for any help
by the way, what is the approximate value of the machine today, I paid $3500 for it 3 years ago. ( with engine running)
Dave Newman
Thu, Aug 2, 2007 8:55 AM
country
the serial # is 78649
Thu, Aug 2, 2007 8:56 AM
Willie
Reply to country:
Its 1928 vintage one of the last made they stopped at 78989 you can get rings from Hastings I dont have their info and gaskets from Olsen http://www.olsonsgaskets.com/products.html
Thu, Aug 2, 2007 9:36 AM
country
Thanks for the info
would you have the torque specs for the head bolts?
also, any idea on value? ( after it is running again)
Dave
Thu, Aug 2, 2007 6:37 PM
Reply to country:
Thanks for the info
Dave
Hi Country,
no specific tensions are given for these units but the attached should help.
Cheers, and Welcome to the BB.
Thu, Aug 2, 2007 6:45 PM
country
Reply to edb:
Hi Country,
Eddie
thanks for the info
I have been a memebr for YEARS- mostly jusk lurking
see if this looks familiar, as I posted it several years ago
http://www.easternsurplus.net/images/lesnewman.jpg
Dave
Thu, Aug 2, 2007 8:14 PM
Catmatt
Send a private message to Catmatt
Reply to country:
Eddie
thanks for the info
Dave
dave,
where in philly are you located? I am from this area too, near norristown.
Thu, Aug 2, 2007 8:45 PM
country
Reply to Catmatt:
dave,
I work in Phila near the Tacony Bridge and live in Newtown, Bucks county
Thu, Aug 2, 2007 11:42 PM
Catmatt
Reply to country:
I live over near phoenixville. I am doing a job as we speak in newtown on 413 accross the street from the township building. How many cats do you have?
Fri, Aug 3, 2007 1:02 AM
country
Reply to Catmatt:
catmatt
I have the 2 ton, D2- 3J I think, a newer D3C hystat, cletracs: F, K20, 35, E-38, OC6-68, OC3, HG-68, John Deere: 2- MC, 450 loader, Lots of hit and miss and a few wheel tractors, plus a pile of army trucks.
what do you have?
Fri, Aug 3, 2007 4:41 AM
Reply to country:
catmatt
what do you have?
Hi country,
sorry, ran out of att. post space so had to delete the data. Always save anything you see of interest as post space is limited and to answer others queries we have to keep deleting former post data.
Sorry, can only post "tension 2", as no space left until I delete some thing recently posted--won't do that yet to give others a chance to see and save it!!!
Cheers Eddie B.
Thu, Aug 23, 2007 12:43 PM
