cat 15 steering clutch plate thickness
Opies Cats
Send a private message to Opies Cats
does any one have specs on how thick the steel and fiber plates are in thousands  and what is the spring pressure is for testing springs
Mon, Jun 6, 2022 4:37 AM
side-seat
I measured three complete steering clutch assemblies the best I could that are laying round my shop as follows:
All are assembled with 7 floater rings and 7 Fiber Disks.
#1 Stack= 2.650" Fiber disk= .310"
#2 Stack= 2.625" Fiber Disk= .300"
#3 Stack=2.710" Fiber Disk= .310"
I have a pile of unriveted linings that some look new but not sure and they measure .125" to .140" thick. Seems the majority measure .125"
If you add the steel toothed piece (.065") and two of the loose disks I have ; that comes to .315" .
I'll be into all that when I get to assembling my 15 in the next few months I hope. I maybe changing out some perhaps.
The springs not sure but you may be able to figure out the strength by measuring the wire diameter. I don't have any clutch packs taken apart to get the overall height .
Tue, Jun 7, 2022 7:28 AM
