CAT 15- oil pressure guage dis-assembly question
janmeermans
How does one go about accessing the face of an original CAT 15 oil pressure gauge? I searched the archives but did not see anything. I was able to get both of the screws out of the gauge but I am not sure what is the next step. Obviously, I do not want to mess up a 80 year old working gauge which just suffers from the face plate paint flaking off and now they are laying in the bottom of the gauge. Can one push the gauge out of the "mounting cup" so the rear fitting goes through the back of the "cup"? If so, it looks like a vise would need to be used.
Thanks in advance
Jan - Cat 15, PV 7207
Thu, Dec 27, 2012 12:20 AM
nw4evr
Send a private message to nw4evr
i got a couple of mine apart, so i could touch up paint the black inside by the numbers.... maybe i was just lucky,,, but i believe it was just by working the outer ring clockwise and ccw while maintaining "pressure" outwards. It came apart, it did not break the glass, and mine were not threaded or crimped too much. I would use much caution using a vise, by staying away from the glass front, i used a channel lock pliers to get the rotation going, then kept at it,,, good luck
R2 5E 3542 SP, 22 2F, 22 1J
Thu, Dec 27, 2012 12:36 AM
Inter674
Reply to nw4evr:
could be the same on the D4 the Smiths guage face is a brass ring crimped over a seal. I spent some time prying the brass from the rear outwards until it was clear enought to slip over the seal and glass. Re=crimping is easier just use a screwdriver handle or such like and apply pressure to push the brass back into its crimped shape, checking to make sure it is tight, ie to the extent that it cannot spin on the glass/seal.
Thu, Dec 27, 2012 3:49 AM
brewzer
Reply to Inter674:
Give me a call and I can explain how to get the face off he guage. I have done this several times and it works good. I will send you a pm with my phone number. - Wally
Thu, Dec 27, 2012 4:10 AM
