Cat 15 oil line fittings
Nospark015
Send a private message to Nospark015
Hello All:
  Cat used a different appearing  compression compression ring fitting on the oil lines of the 10, 15 and 30.  They had a cone shaped compression ring unlike the common olive shaped brass rings and a different nut. Does anyone know what these are called and if they are still being made?   Any thoughts would be greatly appreciated!
Fri, Oct 11, 2024 7:49 AM
| Kingaroy, Queensland
