cat 14e motor grader
Showing 1 to 10 of 10 results
dover
Send a private message to dover
Hello,
I just bought a 14e motor grader to take care of the road to the new house. It came with a service manual that lists the vin# of c35f-1028. I was just wondering if anyone had any good info on year(was told mid 60's), or anything else I should know. Pics Attached.
Thank you,
Ben
Mon, Jun 2, 2008 12:10 AM
SJ
Send a private message to SJ
The Cat book says they came out in 1959 so it could be a 1960 grader as my book only has start up dates but some on here has books with the exact date of manuf.They are listed as a 14C and not an E series. The book says the 14D came out in 1961.
Mon, Jun 2, 2008 2:21 AM
Thank you received: 63
Reply to SJ:
14C - 35F1028 is a 1960 model.
Mon, Jun 2, 2008 3:30 AM
dover
There is another vin that is something91something. I'm at work and dont have the books so I can't tell for sure. The book lists it as an E so that might not be the right vin or wrong book? Where should I look on the machine to see if the vin tag is still there? It runs well and has a V plow also and form my digging the $5,000 I paid looked like a good deal, any imput on that?
Ben
Mon, Jun 2, 2008 3:52 AM
SJ
Reply to dover:
Ben
The serial number should be on the left rear of the block just below the head so look there.I can,t remember if or where a 2nd SN plate is on them but maybe someone else can help there.The 3 14E SNs are 72G & 99G & 12K so you need to check the serial number before we guess any more on it. The 14C grader is a 35F serial number so look for a 35F on the SN plate or any other number.
Mon, Jun 2, 2008 4:13 AM
Reply to SJ:
Should be another tag forward on the LH frame rail just behind and above the front wheel.
Mon, Jun 2, 2008 8:03 AM
dover
The parts book lists serial numbers of 96f1. I will look at the machine on Thursday, but I doubt the tag on the front will still be there.
Thank you,
Ben
Tue, Jun 3, 2008 4:43 AM
Reply to dover:
Thank you,
Ben
The 96F1-up series is a Model 14D (1962-1965)
Tue, Jun 3, 2008 7:43 AM
Eds-oldiron
Send a private message to Eds-oldiron
Dover..I bought a 96F 14D in 1999 for 4 thousand, had a bad axle, support, bearings, etc, etc,. Spent 2 thousand getting it fixed. Stong machine, it would easily push a moldboard full of dirt. I used it for over four years and sold it for 10 thousand, I think you did all right, if everything works.
The 14D 96F has a 4sp trans with a forward and reverse lever. The 14E 99G has hydraulic over mechanical controls. A couple of ways to tell them apart.
Tue, Jun 3, 2008 9:42 AM
dover
Reply to Eds-oldiron:
Mine is straight nuckle buster controls so it must be a C or D. Everything appears to works other than the brakes, blade slide, and blade roll. I didn't think 5 grand was a bad price before I found out it had a Vplow and extra set of brand new edges.
Ben
Tue, Jun 3, 2008 9:32 PM
dover
I checked the tag and sure enough it is a C. I put it to work Thursday after a good storm Wednesday and did a very good job for a non blade operator at the controls. I also made $100 from a neighbor so I only need to work 49 more roads and she'll be paid for, minus fuel. I have a good leak from the "power" steering box but all in all it did well.
Ben
Mon, Jun 9, 2008 2:21 AM
