I show a couple (SAF) South Africa machine models:
A 34K from 1968 - 1974
A 73H from 1970 - 1971
49V16606 is the engine serial number for a 3306
6A784 would be the engine arrangement number.
There should be a grader model/serial number on the grader frame....doesn't say where, looks like LH side.
These machines would be very similar to the US 13K model from 1967 to 1973.
The tandem drives use SAE 90 oil (32 deg. F and above) (6 gallons ea.)
The transmission and rear axle housing have the drain and filler on the square cover of the rear axle housing. Fill to top of filler neck.
Have you tried adjusting the main clutch?
[quote="Old Magnet"]I show a couple (SAF) South Africa machine models:
Have you tried adjusting the main clutch?[/quote]
Thank you Old Magnet.
I have searched for the serial number all over, i surpose that the previous owner removed the makers plate.
The filler plug which you refer to i did remove and it were full, but it seemded very thin, i did not drain it yet, should i fill it with 20w50 Agri multigrade? (which we use here in tractor gearboxes, engines etc)
In regards to the clutch;
I have adujsted the rod from the peddle to make sure it have free play. i dont find any other adjustment, however on the left hand side is an inspection cover on the bell housing. I can see inside but do not want to fidle with it unless i know what to do.
I really appresiate your help, if ever you come to South Africa, you are most welcome to come and spend time on the farm in the waterberg.
We have a big problem in South Africa in regards to capable mechanics, due to the political problems most of our fellow Boers who knew these machines have moved away to other countries.
Boere Groete
