Cat 12 Stuck Clutch
Cat 12 Stuck Clutch
mvoth
Send a private message to mvoth
I have a Cat 12, Serial number 70D1254. How do you get a clutch unstuck?
Fri, Feb 20, 2009 11:00 AM
Check the adjustment so you know you have it releasing properly.
Does it feel like it's operating correctly. Did it work correctly last time it ran? Has it been sitting up a long time or did this happen suddenly with loss of free travel? Just wondering if the clutch could have stacked a lining and not be releasable. I doubt that would happen while sitting up unless you had water in the clutch and maybe not then.
If it happened over a long time sitting then attempt to pull it in as high a gear as possible with compression and w/o fuel on and see if you can slip the clutch by holding it down while pulling. Have the blade near the ground for emergency stops in case it cranks somehow.
Other alternative is to pick a good area and push it off in as high a gear as practical and work the steam out of it with the clutch held in. If you can't grade, you could try to hit the brakes and slip it or chain it back to the pushing tractor and let it try to drag that after you get it going. Again blade kept near the ground for emergency use.
Higher gears strain the clutch the most.
Fri, Feb 20, 2009 11:46 AM
Tim R
Send a private message to Tim R
I had luck a few times by. Some how hold the clutch lever in the release position with block or chain then put the trans. in 3 or 4th gear and the engine compression on and no fuel you don't want it to start, then with another tractor move the grader back and forth a short distance. When the fans quits moving it broke free. Good Luck
Sat, Feb 21, 2009 10:20 AM
| Hartley - South Australia
