9f327 is the wheel casting number, 9F326 is the correct part number for your wheel assembly.
Hi, Etbrig123.
Bear in mind that those hubs are a press fit on the axle with a largish 'Porta-Power' style hydraulic press at something like 20 - 30 tons. I forget the exact figure but somebody here is likely to have it. Trying to hold them on with just the retaining nut will only result in you having some more junk.
Also, if the hub has been rattling around on the axle for even a relatively short period, you are unlikely to be able to get a good fit unless you replace the axle as well.
Hi, Etbrig123.
I have seen pullers set ups for removing the hub but have never seen anything for pressing it back on. Do you no how they go about doing that??
