Hi range, 3rd or maybe 2nd. 3rd will be pretty fast once it starts, but will pull easier than 2nd.
Does it have brakes or do you have to use the 12 foot brake under the middle? If the 12 footer, have it close to the ground, couple inches is not too close on level surfaces, so you can stop quickly.
