Cat 12 grader
Cat 12 grader
Rep0144
Send a private message to Rep0144
I just got a 9T212 Cat 12 grader and was wondering if anyone knew if 13 x 24" tires would work in place of the 10 x 24" tires that are on it now they are in real bad shape 1 blown.
Sun, Mar 27, 2016 8:24 AM
They would be huge.
I doubt you could use two together in the back on the tandems without them rubbing each other or the tandem drive housing. You certainly want all 4 tires on the rear the same size because there is no differential between sides or between front and back on each side.
Tires for the 212 are a bit scarce. Seems like several years ago Denman made a commercial tread (or maybe it was a spade grip/farm tread) for that size.
Sun, Mar 27, 2016 9:00 PM
Thank you received: 77
They would be huge.
Miller sell various x24 sizes (they list an 11.5x24 with 10x24 in parentheses I guess as a compatible. Take a look at the various options on this page http://www.millertire.com/categories/rear-tractor-tires/
I get my lawn tractor rubber from these guys and have been happy with them. They have a bunch of less common stuff as well.
Sun, Mar 27, 2016 11:19 PM
AGES CAT
Send a private message to AGES CAT
I have 11.2 x 24 tires on our machine. They work well and there are no clearance issues. These were new old stock Goodyear with more than adequate load rating for the machine.
Mon, Mar 28, 2016 1:38 AM
AGES CAT
Reply to AGES CAT:
I have a friend that also used the 11.2 x 24 tires on his 212 as well. We bought these from Schwanke Equipment in Wilmar, MN.
Mon, Mar 28, 2016 1:41 AM
